Can RoboHelp be used without a database on server?
Mar 8, 2013 11:59 AM
We have 2 users using RoboHelp 8 with Word on their Windows 7 PCs. The documents are stored in a SQL Server 2005 database on a server running RoboSource Control 3 (not the full RoboHelp Server product). Now I am being asked to set up a virtual PC with RoboHelp 10 but they don't want the server upgraded. Instead, they just want to put their documents into RoboHelp on this PC. Is this possible? Can one use RoboHelp as a standalone product on a single PC and open up help files in it, without having a backend database like we do now?
    Mar 8, 2013 12:03 PM   in reply to mlouie
    Your question is a bit confusing - are you talking about the RH project files or the help files generated by RH? Running source control doesn't equal RH Server.
    Mar 8, 2013 12:18 PM   in reply to mlouie
    The installs of RH8 will check out the project files from the source control repository in order to be worked on locally. When they're done, the project files get checked back in. When help is ready to be created, one of them will check out the project and create the help file(s) Re: Can RoboHelp be used without a database on server? locally. Where they get placed after that is up to them.
    If you install an instance of RH10 and connect it to the source control repository, upon checking out the project, it will be upgraded. After it's upgraded, it will no longer be able to be worked on by the RH8 installs. If this is to test RH10, I suggest having either a copy of the project made and brought into the RH10 instance (to be upgraded & played with) OR you mimic the source control structure in the virtual instance along with the RH10 install.
    It all depends on what they're trying to do - see how RH10 will work with the project or see if RH10 will work with the source control structure?
    Mar 8, 2013 12:39 PM   in reply to mlouie
    No, that would violate the terms of the RH license - you can't have multiple people working on the same machine using the same copy of RH at the same time. If they wanted to have just 1 author work on the machine at one time, then you could eliminate the source control element (since all SC is designed for is making sure multiple authors don't stomp on each other toes when working on the same project) and keep the project files local.
    Mar 8, 2013 12:47 PM   in reply to mlouie
    If it's installed on a virtual machine on a server, it probably violates the licensing - call Adobe and see.
    Mar 9, 2013 9:45 AM   in reply to mlouie
    Hopefully Adobe have clarified things for you.
    My understanding is as follows.
    1. The licence is per user so if John and Jane are going to access the virtual machine, you need two licences. Using a VM is not a means of having more than one person using Rh, even at different times. That may have changed and only Adobe can confirm that.
    2. If only one person is using Rh at any one time, you don't need source control other than for backup purposes and there are other ways of creating your backups.
    @petergrainge
