berdy11
CS5.5
Mar 9, 2013 6:02 AM
Tags: #project
How can I copy a part of a project (several clips editted together) to another project to combine them ?
    Mar 9, 2013 6:06 AM   in reply to berdy11
    Have you tried import project/sequence?
    Mar 9, 2013 8:00 AM   in reply to berdy11
    A stupid question, but how do you import a sequence exactly?
    Mar 9, 2013 8:22 AM   in reply to Fuzzy Barsik
    Not stupid.
    Import a project.  You'll get a dialog box asking if you want the whole thing or just selected sequences.  Choose selected sequences and dynamic link will present you with a list to choose from.
    Jeff
    Mar 9, 2013 8:48 AM   in reply to Jeff Bellune
    Jeff, I was wondering how OP had been doing that...
    Mar 10, 2013 12:37 AM   in reply to berdy11
    If you do not want to do any further editing of the section you wish to use in another project, you can export the section you want (export the work area only not the entire sequence) as a single clip.  Then import this to your other project.
    If you do this make sure that you use a codec for the export that does not reduce the quality of your media.
    Having said that, "Import Sequence" should import the clips in the sequence together with all applied effects and audio tracks.
    Mar 10, 2013 1:05 AM   in reply to berdy11
    Berdy,
    Go to File / Import / Import Project / Import Selected Sequences.
    Select the sequence you want and wait for the importing to finish. Then double click on the imported sequence in the project panel. That will open the sequence in the timeline with all individual clips, transitions and effects available (at least with CS6).
    Mar 10, 2013 3:01 PM   in reply to berdy11
    Is the sequence you imported the original multi-track sequence with the individual clips and tracks in the timeline or a master sequence? You have to use the original sequence.
