kjhfwe98ywfqfew
column chart solid color stroke with fillfunction
Mar 9, 2013 9:56 PM
in a column chart I am using the fillfunction,
to customize the color of each column.
Now I need to modify,
for each column also the solid color stroke,
but I can't figure how can I do that.
Some one can help me ?
Thanks a lot
Jody
    Mar 10, 2013 8:17 AM   in reply to kjhfwe98ywfqfew
    Depending on what you are trying to do, you need to either:
    create an Array with the colors
     [Bindable]
         private var warmColorsArray:Array = new Array(
            new SolidColor(0xFF0033, .5),
            new SolidColor(0xFF0066, .5),
            new SolidColor(0xFF0099, .5)
         [Bindable]
         private var coolColorsArray:Array = new Array(
            new SolidColor(0x3333CC, .5),
            new SolidColor(0x3366CC, .5),
            new SolidColor(0x3399CC, .5)
    And then just add that array to the fill parameter
     <mx:ColumnSeries
                    xField="month"
                    yField="profit"
                    displayName="Profit"
                    fills="{warmColorsArray}">
               </mx:ColumnSeries>
    Or, you need use the fillFunction to set each item individually.
    Here is the results from an example I did, in order how to do it. And I put a post on my blog explaining what I did.
    Mar 10, 2013 5:51 PM   in reply to kjhfwe98ywfqfew
    From your images, are you trying to change the drop shadow color?  Or are you trying to make the column semi-transparent, with a solid border  like the line graph?
    It doesn't seem that iFill has the capability to change the stroke.  You would probably have to create a new Item Renderer and draw a rectangle with a border and fill to replace the column.
    Mar 11, 2013 7:09 AM   in reply to kjhfwe98ywfqfew
    I did a quick example on my blog of using an ItemRenderer on a ColumnSeries.
    I used the xValue to determine which color to display.  I set the Rect stroke and fill on the set data function.
    Here is an image of the results.  And the View Source of my example.
