FlexSlider
Mar 9, 2013 6:28 AM
I am a beginner in web mastering. Please tell me in simple words how to configure the widget FlexSlider - what html and CSS are needed so that slide show is taking place in the header of my page. www.naszchleb.pl/test2  . I want a slide show in the place of the header picture (the picture with loaves of breads). I have downloaded the flexslider widget into my dremweaver CS6 and have 5 pictures of identical size as the current header picture, which I want them to be part of the slideshow. I want the automatic slideshow only, with these 5 (or more) pictures moving vertically to start with. No thumbnails pictures. Thanks in advance for your guidance.
    Mar 9, 2013 6:32 AM   in reply to Bogi13
    The instructions are right here -
    http://www.woothemes.com/flexslider/
    Can you follow them?
    Mar 9, 2013 7:14 AM   in reply to Bogi13
    In your page, change this -
    </head>
    to this -
    <!-- Place somewhere in the <head> of your document -->
    <link rel="stylesheet" href="flexslider.css" type="text/css">
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.6.2/jquery.min.js"></script>
    <script src="jquery.flexslider.js"></script>
    <!-- Place in the <head>, after the three links -->
    <script type="text/javascript" charset="utf-8">
      $(window).load(function() {
        $('.flexslider').flexslider();
    </script>
    </head>
    That completes step 1 and step 3.
    Then change this -
    <div id="header"><img src="images/header.jpg" width="960" height="310" alt="bbb"></div>
    to this -
    <div id="header" class="flexslider">
    <ul class="slides">
      <li><img src="images/header.jpg" width="960" height="310" alt="bbb"></li>
      <li><img src="..."></li>
    </ul>
    </div>
    The slider is installed.  Now to make it work the way you want (vertical slide), change this -
    to this -
       $('.flexslider').flexslider({
              animation:slide });
    and you will be well on your way. See how it looks.
    Mar 9, 2013 7:16 AM   in reply to MurraySummers
    YIKES - that doesn't look the way it should! Hang on. I'll try to fix it.
    Mar 9, 2013 9:07 AM   in reply to Bogi13
    Change this -
    </head>
    to this -
    </script>
    </head>
    Then change this -
    to this -
    <ul class="slides">
    </ul>
    </div>
    to this -
              animation:slide });
    Mar 10, 2013 6:10 AM   in reply to Bogi13
    It looks like my instructions were not complete.  You need both the linked CSS file and the linked javascript file still!
    They can both be found here - https://github.com/woothemes/flexslider. Download both of these into the root level of your local site, then upload them to the server and you should be good to go.
    Mar 10, 2013 5:03 PM   in reply to MurraySummers
    thanks murrary, this solved the problem, for me at least
    Mar 12, 2013 11:53 PM   in reply to MurraySummers
    Hello.i have read ur steps.It is very useful.Pls let me know how to reduce the Flexslider's height & increase its width.
    Thanks in advance.
    Mar 13, 2013 5:52 AM   in reply to Roopavathy
    Change the size of the images within the slider container.
    May 3, 2013 12:01 AM   in reply to Bogi13
    Can you open the stylesheet by clicking the file(flexslider.css) from the top in the design view?
