I have a graphics designer that designed a home page and I want to bring it over to Dreamweaver
I know how to create sites in DW, but I'm not very familiar with Illustrator. I know that I need to create slices and I know how to do that, it just that I'm trying to figure out the best way to do this. This process I will need to repeat over and over again, so what do you think is the best way to create the slices for a design. My situation is that I was given an Ai file and I need to use move this file without losing the depth of the images to DW. Putting it into a flat file or saving the entire thing as an image is not acceptable. Should I create the slices manually, by objects or what is the best way? I have 9 layers in the page. Is there a way to create a slice for each of the 9 layers? Thanks, your help is appreciated.
There's no way to answer this in generic terms. Actually, translating a page mock-up from Illustrator is no different than translating one from Photoshop.
Slicing up may be the correct approach for certain pieces of it, while other pieces might not need slicing.
Okay then, the only thing to do now is to use your knowledge to analyze the mock-up and plan your page regions. Draw up the divs and make decisions with respect to how the elements of the mock-up will be contained by them; as background images, image slices, etc.
If you're looking for a simple method that equates to Illustrator file = (clean) Dreamweaver HTML/CSS, you're not alone. Let us know if you find it.
North America
Asia Pacific
