Passing data between views
Mar 9, 2013 6:54 PM
There is not much basic data on this on the net, can someone help me out with this issue?
I have this spinner list that I want "data" to be sent to a view called "View 2"
How do I write the code in "View 1", and then the receiving end "View 2"?
Can I write it like this:
protected function View 1():void
   navigator.pushView(views.View 2, data);
This is a spinner in "View 1" I want the "data" to be sent to "View 2":
s:SpinnerListContainer x="22" y="85" width="135" height="110">
  <s:SpinnerList id="ToolSpinnerLeft" width="125" change="ToolSpinnerLeft_changeHandler(event)"
        fontWeight="bold" labelField="data" selectedIndex="1">
   <s:dataProvider>
    <s:ArrayList>
     <fx:Object data="Test 1"></fx:Object>
     <fx:Object data="Test 2"></fx:Object>
    </s:ArrayList>
   </s:dataProvider>
  </s:SpinnerList>
</s:SpinnerListContainer>
    Mar 9, 2013 8:42 PM   in reply to fsoender
    IMO, your views should share a model.
    Mar 10, 2013 9:15 PM   in reply to fsoender
    Well, you can cheat and store it up on your application and get it from there or FlexGlobals.topLevelApplication or use some sort of Singleton.
    Mar 11, 2013 8:32 AM   in reply to fsoender
    Probably because it is a variable and needs binding syntax “
    Mar 11, 2013 8:57 PM   in reply to fsoender
    Maybe I’m not understanding the problem.  I don’t see any obvious problems.  What error do you get?  Setting breakpoints and examining objects will probably help.
    Mar 12, 2013 6:19 AM   in reply to fsoender
    Consider using "break" in conjunction with switch/case ..
    Read up about the switch statement again!
