Rich Heins
Photos downloaded into Bridge aren't listed in the order in which they were shot
Mar 10, 2013 8:26 AM
Tags: #cs6
When I download photos from my compact flash cards (from my Nikon D3 & D3s) they don't always load in the order they were shot.  It's annoying to go through sequences of sports shots only to jump back and forth in the sequence.  Anyone know why this happens and how to correct it?
    Mar 10, 2013 8:59 AM   in reply to Rich Heins
    This seems like a Bridge question, so you may want to check in that Forum.
    Anyway what is View > Sort set to?
    Mar 10, 2013 10:01 AM   in reply to Rich Heins
    Occasinally that question comes up a studio shoot with multiple cameras, but it usually is a user error.  The time is recored in 1/100 of a second and are sorted that way.  THe problem arises when the two cameras are not set exactly the same, and set to correspond to computer time.
    Mar 10, 2013 2:13 PM   in reply to Rich Heins
    Rich Heins wrote:
    The sort is set to filename.  The filenames are consecutive but aren't labeled in the order in which they were shot.
    If sorted by file name, you re-name them, and they are now view out of order it is your naming technique.  Be careful of the first character as it sets the sorting.  If you have a blank space then AA it will sort different than if you have just AA.
  • Omke Oudeman
    Nov 27, 2004
    Mar 10, 2013 5:31 PM   in reply to Curt Y
    It is a flaw of either Bridge or Photodownloader or both. It seems not being able to read the milliseconds of the data or this data is not in the correct place. But images taken at high speed are often not in the right order.
    Maybe the scripting forum has a solution for it but it is a long standing problem and knows where to read the correct milliseconds data for a correct sorting order.
    Even 2 or 3 shots taken in the same second can be in a wrong order, let alone the result of High speed motor drive of todays dSLR.
    Mar 11, 2013 12:04 AM   in reply to Rich Heins
    Have you tried sorting by »By Date Created«?
    Mar 11, 2013 9:18 AM   in reply to Rich Heins
    Any idea why they get out of order while downloading?
    Not really.
    But you may want to rename them when in that order; I think renaming just takes the order in which images are listed at the moment.
