Incorporating external sound within a clip without re-encoding
Mar 10, 2013 7:59 PM
I'm hoping someone more knowledgeable than me can save me a bit of time. If Premiere is not capable of doing certain things (see below) then I won't have to vainly search through the manual to find how to do them.
1. Can Premiere automatically align a sound clip that was taken with an external recorder, to the sound already inside an AVCHD clip? A TV cameraman I was talking to recently said that FCP can do it. For a particular clip, he just highlights a series of sound files (if I understood him correctly) and FCP chooses the right one and aligns it to the existing sound.
2. Can I import a clip in AVCHD format (taken on a GH2), remove the existing sound track and replace it with another (for example, as above), and save again as AVCHD, without the video part being re-encoded? What I want to do is store the externally recorded sound files within the clip instead of having them as separate files. Simplify my archives.
I don't need instructions how to do the above, I just want to know if it is possible, and what technical terms to look for in the manual.
    Mar 10, 2013 9:28 PM   in reply to Guy Burns
    1. might be possible if both clips have identical timecode.
    2 can't be done with any software that I know of.
    Mar 10, 2013 10:14 PM   in reply to Jim Simon
    (2) is possible because AVCHD is effectively the same format used on Blu-Ray discs, but it's a little fiddly. There are several third-party demultiplexer (demux) applications available which can separate the elementary streams from the MTS file on an AVCHD media card and give you the H.264 video and AC3/PCM audio streams as separate files, and matching multiplexer apps that will stitch the streams back together again without altering their internal data. If you can create a replacement for your audio stream which exactly matches the original in bitrate/length/timing then it should work just fine, but it's hardly a one-click workflow.
    As this isn't anything to do with Adobe software and these apps are used to extract copyrighted material from Blu-Ray discs I'm not going to give links - but Google for 'AVCHD demux' and you'll find things to try.
    Mar 11, 2013 6:11 PM   in reply to Guy Burns
    Look into a third party application called PluralEyes.  FCPX has this function built-in, FCP7 does not.
