juano28
How do I load an Adobe PDF preset into Bridge?
Mar 10, 2013 10:52 PM
With InDesign I go to File>Adobe PDF Presets>Define>Load. I would like to do the same thing in Bridge so that I am using a PDF preset that I choose instead of the default PDF preset that is in Bridge. I need to know that the PDFs generated from Bridge and InDesign are being generated with the same PDF preset. I am using Bridge CS5.5 on a Mac. Thanks.
    Mar 12, 2013 3:52 AM   in reply to juano28
    I don't think you can do this… Bridge generates it's *.pdf files using the cached *.jpeg previews… Try with some vector files and you will see the result is nothing like ID… If you want them to be the same standard then use ID to make the contact sheets…
