Playback is choppy / slow while speeding up clip anything above 200%
Mar 11, 2013 12:37 AM
Tags: #video #premiere #rendering #playback #play #slow #choppy #render #back #cs6 #duration #speed
Coming from using Final Cut Pro X for a while, ive just bought myself a new laptop.
Basic Specs are:
Intel i7 3840QM 2.8ghz with 3.8ghz turbo
32GB Ram 1600mhz
1TB SATA 7200rpm in Raid 0
2GB GeForce GTX680M
Long story short, ive been a long time PC fan my whole life although using the mac only for video editing and being a basic macbook pro 13" with final cut pro x seems to outperform my newly acquired PC laptop.
I bought this laptop with the intentions to move my video editing platform back to a PC state and with the new Premiere cs6.
everything is smooth and all that but the same issue i remembered about premiere back when i wanted to try it out in cs3 time. the playback for previewing video is slow and choppy.
i have to always "render" my video just to preview it smoothly which is very time consuming. I always thought because back in the day my laptop wasnt as good as my new one now so that was the issue and moved over to my mac which was great for video editing only.
but that mac has basic specs compared to my new laptop and still the preview is flawless and smooth with LIVE video previewing. i mean i can do speed duration changes of 10% slow down all the way to 1000% speed ups and watch my video that same instant after.
but with premiere if i do anything speed changes of more then 200% original frame time it plays fine for 2 seconds at that accelerated speed then gets choppy and slow.
I even changed the playback resolution to 1/4 quality and i get the same issue.
i wouldnt mind waiting for the render so i can see that smooth playback and determine whether i like it or not except when rendering my clips from my gopro which is recording at 60fps 1080 it takes over 15 minutes.
This has always seemed to be an issue with premiere for me and am wondering if there is something i am missing here..
anyone point me to the right direction?
im not hating on PC or adobe at all, i love these two platforms in every other way but when it comes to this editing all i hear is good things about them but when i go to use them for myself its extremely frustrating.
P.S. yes i have set my GPU to use the mercury GPU accelerated mode which did minimal difference with playback smoothness.
    Mar 11, 2013 4:33 AM   in reply to awpsome
    Pr isn't optimized for the newer GoPro stuff.  Since FCP transcodes the video on ingest, you may have to do the same with Pr for this type of footage.  You can use the Adobe Media Encoder to batch transcode your footage to an intermediate codec.
    Jeff
    Mar 11, 2013 12:03 PM   in reply to awpsome
    Try the MXF Op1A preset that matches the footage settings and see if it works for you.
    Mar 11, 2013 12:08 PM   in reply to Kevin Monahan
    Hi Kevin,
    The MXF Op1A produces good results, but it's dog slow.  About 4x real-time.  AME/Pr only ever use one core (25% CPU) during encoding.  By contrast, UT (on Windows, and maybe Mac?) uses a little under 50% and encodes a tick faster than real-time.
    Do you get high CPU usage or fast renders with Op1A?
    Jeff
    Mar 22, 2013 6:25 AM   in reply to awpsome
    Have you tried using Cineform Studio to convert to a larger but less complex .avi or .mov file?
    http://gopro.com/software-app/cineform-studio
