I am workin on a film which has been shot on Arricam LT Super 35 camera. The processing lab has sent Telecine tapes which are in DV 25 PAL format. Its now been captured into premiere as 720*480 25fps footage.
My doubt is,
a. should I conform it to 24fps and then start the edit or keep it at 25fps
b. If I conform it, with the pull down method, I will be losing a frame every second. Will this not affect the timecode and subsequently the EDL which I have to send to the Lab.
How does this process really work as I am fluent in editing films shot on Digital but new to TC edit.
Thanks in advance,
Bharath
You would be best served by editing at the
native frame rate of your source material.
Are you working with a 'best light' transfer with the intent
of sending a post-edit scene select EDL to the xfer house
for final color correction?
If so, that is even more reason for you to edit
at your source material's native frame rate.
Hi Joe,
Thanks for replying.Few things,
I was going through the telecine tapes yesterday and noticed that the hardcoded timecode is of 25fps and not 24fps.
Can you also run me through the edit workflow in points. As of now the tape is captured as 25fps PAL 720*576 AVI ( Interlaced).
The idea is to do an offline edit, send the EDL to the lab for DI and meanwhile take DV24p export of the offline edit and send it to the Music and ADR dept.
North America
Asia Pacific
