emmaTPR12
Rotating a single pattern swatch
Mar 11, 2013 6:31 AM
Tags: #illustrator #transform #object #cs6 #rotate #pattern_swatches
I am trying to work out how to rotate a pattern swatch without that rotation affecting all the other pattern swatches on my palette. I don't want the rotation to apply to just one instance of fill, I want to edit the actual swatch so that whenever it is used in the future, that rotation is applied.
I have tried the obvious - eg going to object, transform, pattern only... and it works, but it also rotates all my other swatches; and I can't work out if it's rotating it for just that object or if it's actually updating the pattern swatch orientation.
Additionally it would really help to be directed to some comprehensive and helpful tutorials on making patterns using the updated CS6 software - everything I've found so far just raises further questions for me. I'm talking about, for example, being able to change the width or rotation of a stripe within a pattern and have it still tile seamlessly.
I'm using CS6 on a PC. Thanks....
    Mar 11, 2013 7:24 AM   in reply to emmaTPR12
    Could you please post examples of your artwork when you experience the problems?
    About the rotation of tiles: You could drag the pattern swatch onto the artboard, rotate it there and drag it back. Not entering the pattern editor should be easiest in this case.
    Everyting about the technical nature of patterns still apllies the pattern swatches (e.g. the invisible rectangle in the background)
    Mar 11, 2013 7:35 AM   in reply to emmaTPR12
    Apply the Pattern then use Object > Transform > Rotate
    untick the Transform Object box and enter your rotation degree.
    You don't need to alter the actual swatch at all.
    Mar 11, 2013 8:03 AM   in reply to emmaTPR12
    OK, in this case: see Scott. I was thinking of rotations that make sense in this case, like 90°
    Mar 11, 2013 8:21 AM   in reply to emmaTPR12
    I suggest you set pattern the fill rotation by using Scott's instructions or visually, by holding "~" key as you rotate using the rotate tool. This will rotate only the fill, not the object.
    Once you have desired rotation, save the Appearance as a Graphic Style and assign it to any other object. You can save any number of "Graphic Styles" based on the same Swatch Pattern.
    Mar 11, 2013 9:21 AM   in reply to rcraighead
    Depending on what type of keyboard you have, it may be the < key (to the left of Z) instead of the tilde key.
    Mar 11, 2013 10:28 AM   in reply to emmaTPR12
    Do you know how to create a pattern swatch? You can check here for the constraints on patterns
    http://help.adobe.com/en_US/illustrator/cs/using/WS714a382cdf7d304e7e0 7d0100196cbc5f-64d6a.html
