bunkerramo
need help syncing and editing together .mov and .mxf clips.
Mar 11, 2013 11:19 AM
Tags: #edit #clips #mxf #mov #syncing_video
I put avchd clips from olympus omd  camera in one sequence and mpeg2 clips from canon xl 100 camera in sequence 2. I put markers in each seq at sync points.  Premiere 5.5.2 won't let me sync them  if I bring seq 1 into seq 2. How do I sync them and then edit them in the multi camera window? I have windows 7 with mercury engine and CS 5.5 premium.  12 gig ram
    Mar 11, 2013 12:14 PM   in reply to bunkerramo
    Hi benkerramo,
    The way you should work is to mark a sync point on all the clips in the Project panel not the Timeline panel. Then, once you have your sync points for all the clips you would make a multicamera sequence from that.
    See Mark Clips for Synchronization: http://helpx.adobe.com/premiere-pro/using/editing-multi-camera-sequenc es1.html#id_78669
    Mar 12, 2013 3:56 PM   in reply to bunkerramo
    I find the best way to do this is to create one sequence and add all your clips to that.  Sync them up manually.
    Then create a second sequence, nest the first into it, right click and Enable Multicam.
