DonCoppockII
Dreamweaver does not auto-complete </script> tag
Mar 11, 2013 11:19 AM
Tags: #script #dreamweaver #tag
Dremaweaver CS5 Version 11.0 Build 4993 - does not close script tag. I type <script> include the text then type </   and the Script tag is NOT closed.
When I type </  the script tag should complete and close automatically.
So, for example:
<script type="text/javascript" language="javascript">
function closeThisWindow() {
     window.close();
I have to type </script>  because it does not auto-complete.
Don.
    Mar 11, 2013 11:29 AM   in reply to DonCoppockII
    Go to Edit > Preferences > Code Hinting.
    Put a check mark by Close tags after typing the open "<" tags.
    Hit OK.
    Nancy O.
    Mar 11, 2013 11:42 AM   in reply to DonCoppockII
    I can't reproduce this in CS6.  Do you have the latest udpates for your product?
    http://www.adobe.com/support/dreamweaver/downloads_updaters.html#dwcs5 1104
    Nancy O.
    Mar 11, 2013 12:06 PM   in reply to DonCoppockII
    I can reproduce your symptoms, and I've learned to live with it. I'm using the permanent CS6 (not Cloud).
    Mar 11, 2013 12:09 PM   in reply to DonCoppockII
    That's just how DW works.
    You can file a bug report if you think it will do any good.
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Nancy O.
    Mar 11, 2013 1:07 PM   in reply to DonCoppockII
    I think this is very intentional on the part of Adobe's development folks. I think the reason they have left it this way all these years is because you can use one or many </ in a javascript and not be in the process of writing the end tag for the opening <script>.
    In my opinion, it would get more than a little annoying to have to undo the auto-insert every time you wanted to have a javascript write html into your page  and it kept closing the <script> instead of allowing you to choose to close it or not.
