jatjat1000
How to copy from one image to another
Mar 11, 2013 1:22 PM
Hi, I'm struggling with the most basic process in PSE 10. I have selected an area in a photograph - now I want to delete the rest of that photograph and add the selected area as a layer to another photograph. Having spent hours searching online, I'm hoping someone can give me an answer please.
John
Message type was edited by: Brett N
  • 99jon
    Jan 6, 2010
    Mar 11, 2013 11:21 AM   in reply to jatjat1000
    After you make your selection click Edit >> Copy
    Switch to your other image and click Edit >> Paste
    Then use the move tool to position/scale
  • 99jon
    Jan 6, 2010
    Mar 11, 2013 11:38 AM   in reply to jatjat1000
    Make your selection and press Ctrl+J to place it on a separate transparent layer.
    Drag your second image into the main editing window then look in the layers pallet (Window >> Layers if its not visible)
    Highlight yout top layer and drag it down the layers stack and drop it below your layer with the selection which should become the top layer.
    Highlight the top layer and use the move tool then re-save.
  • 99jon
    Jan 6, 2010
    Mar 11, 2013 11:50 AM   in reply to jatjat1000
    What selection tool are you using and on what type of image?
    Mar 11, 2013 12:03 PM   in reply to jatjat1000
    Check your layers panel. When you get that error it is because the layer you are selecting is blank.
    A Selection selects pixels on the currently active layer. If you have a blank layer, even though you can see through to lower layers and their contents, your selection is just a bunch of nothing.
  • 99jon
    Jan 6, 2010
    Check if the image is 16 bit. If it is go to Image >> Mode
    Change to 8 bits/channel
  • 99jon
    Jan 6, 2010
    Mar 11, 2013 12:13 PM   in reply to jatjat1000
    Or try Layer >> Duplicate Layer
    Then work on that layer rather than the background.
    Mar 11, 2013 12:16 PM   in reply to jatjat1000
    There's no reason that this wouldn't work on a tiff file. TIFF is very often used for editing, more than PSD even. At the top of the image tab there are some numbers and letters that will say something like *(RGB/8). What does that say?
    Mar 11, 2013 12:50 PM   in reply to jatjat1000
    Okay, so that's not the problem, then. 8/bits channel should be grayed out (that means it's what you already have), and you have an RGB image, so neither of those is the problem. Did you try deleting the preferences yet?
