I have a lot Flash animations and tutorials with lots of buttons for navigation, text boxes for user input, and a lot of ActionScript 3 code. You can see what I've done at http://preparatorychemistry.com/Bishop_animations.htm and http://preparatorychemistry.com/Bishop_Tutorials.htm. I have Flash CS6.
Every once in awhile I search the Net for information about how to convert my animations to something that will work on iPads. I did that again today, and I'm once again confused. I tried Swiffy, but many of my files are too big or have code it doesn't recognize. What are people doing for this? What's the next thing for animations like mine? Is it HTML5 for sure? Will HTML5 do what my animations and tutorials do?
Thanks for the help
Mark
You could use your current Flash files and output them as iPad apps using AIR for iOS (http://www.adobe.com/devnet/air/air_for_ios.html), although you will have to register as an Apple Developer first to be able to create the .ipa installer files used by iOS.
Yes it does as it is essentially a normal Flash project inside a runtime (AIR) just as a .swf works inside the Flash Player browser plug in.
As a contract Flash Developer I have done nothing but AIR projects for the last 12 months and have AS3 projects running on Windows Desktops, tablets running iOS and Android and of course iPhones.
making apps with AIR is a totally different workflow from what you asked for in the first place.
You have to be clear about the drawbacks:
1.Your content can`run inside a browser
2.It has to bring its own Runtime (AIR instead of Flash)
3.You can only distribute via itunes and (biggest One)...
4.Apple has thelast word over every incremental change of your app
You're correct...my thoughts have changed since my original post. I had the hope (delusion??) that there would be a one button way to convert my Flash projects into whatever. I've come down to Earth now. I have a one-guy operation, and I'm not ready to learn how to make my animations from anything other than Flash. I'm thinking that the AIR option might be a short-term, less than optimal option. You mentioned that I could only distribute the AIR apps from iTunes. Does this mean that I won't be able to make them available from my own website? How does Apple maintain control? To go the AIR route, do I need a developer certificate and provisioning profile? If so, how do I get them?"
CORRECT, you will depend on itues to distribute it for you
They can make/break your app by rejecting it, thus rendering your work pointless.
YES,
search apple developer
You can get a Developer Certificate and the Provisioning Profiles by signing up (and paying) to become an Apple Developer at https://developer.apple.com
You can distribute AIR apps outside of iTunes by using a type of Provisioning Profile called "Ad Hoc" which limits you to distributing up to 100 devices, all of which you must have the serial number of.
You can add the serial numbers of up to 100 devices in your dev account and then create a Provisioning Profile that only allows installation on those devices. You then send out the app and the profile to users who add the two files to their iTunes app and in turn connect their device to iTunes via USB and install the app.
Ad Hoc distribution is for testing purposes rather than bypassing the App Store!
Thanks...this is all very useful (and disappointing) information. I just assumed I could distribute the Flash-AIR files from my website.
It's a shame that Apple won't allow Flash on iPads and iPhones. Doesn't it hurt iPad sales that they are crippled by not being able to run Flash animations? My textbook is used in some high schools, and many high schools are talking about moving to tablets for textbooks. I recommend against adopting iPads as the standard because of their inability to run a lot of web content.
I did sign up and pay to be an Apple Developer, but I still can't figure out how to get my developer certificate and provisioning profile. Are they supposed to send me a link...passcode...files??? I paid and filed out the forms two day ago.
thanks again
North America
Asia Pacific
