y.kulyk
16 - 32 bit image data conversion
Mar 12, 2013 12:17 PM
Tags: #rgb #c++ #32 #filter #bit #16 #indata
Hi all
Could someone pelase explain me how I can convert 16 - 32 bit RGB image from FilterRecord::inData to 8 bit RGB, and than how I can convert back 8 bit to 16 - 32 bit RGB image to store it in FilterRecord::outData. Maybe there exist some information in documentation or in some sample? I'm asking because I didn't find it.
Thanks for help!
Best Regard
Yaroslav
    Mar 13, 2013 1:14 AM   in reply to y.kulyk
    A simple bit shift will convert the data if you only want a linear conversion. Are you sure this is what you want though as you will loose a lot of image data converting to and then from 8 bits?
    James
    Mar 23, 2013 2:03 PM   in reply to y.kulyk
    You might want to read the documentation.
    32 bit/channel is floating point values.
    16 bit/channel ranges 0..32768.
    You don't want to do simple bit shifts.
