udance4ever
Divide Scanned Photos: possible to salvage when background is white?
Mar 13, 2013 12:32 AM
Tags: #background #white #split #divide #pse11 #multiple_photos
Hi!  I think Divide Scanned Photos feature is amazing!
http://helpx.adobe.com/photoshop-elements/using/cropping.html#divide_a _scanned_image_containing_multiple_photos
for those scans I put black construction paper in the rear, it works like a charm.
however, my mom scanned multiple photos prior to us finding Elements and did not use a dark background.
Is there any way to salvage this or is it too late?
when we attempt to Divide Scanned Photos on a set of B&W photos with a white background, no luck.
PSE11 just spits out a copy of the same photo
    Mar 14, 2013 4:24 AM   in reply to udance4ever
    Hi ,
    If PSE only make a copy of the original image it means it does not able to find the edges.
    It should be scanned with dark background which clearly alienated the images seperately .
    you can try "divide scan photos" feature after increasing the resolution of the image .
    1)Go to Image menu >> resize >> Image size
    2)check on the resample check box.
    3)Increase the resolution .
    4)try again "Divide scan Photos"
    if still it does not do anything , try to seperate the images using selection > layer via cut , crop etc .
    thanks,
