Stratusphere_14
How do I put a div on top of another?
Mar 13, 2013 7:40 PM
Tags: #cs5 #background #image #div #dreamweaver #button #window #tag
I have one div tag for my header, and one for my body. Now I want to put buttons over them, how do I do it?
Any way that I can find leaves the buttons floating out in space, not anchored to the header. So they move around when the window is resized.
Help!
    Mar 14, 2013 5:06 AM   in reply to Stratusphere_14
    Put the buttons *in* the div tag. Make the header image a background image.  Locate the buttons within the header container by using margins on the buttons container or padding on the header container.
    Questions like this are best asked with a link to the page or a copy of the code involved - that way we don't have to guess about what you might have in your code.
    Mar 14, 2013 5:21 AM   in reply to Stratusphere_14
    And do not use AP divs to try to do that.
    For the underlying div (assuming you have a background image) your CSS should be:
    .underlyingDiv {
         background-image: url("/images/myimage.jpg");
    .divThatSitsOnTop {
         margin: (some margin code that places the div where you want it);
    Your html will be:
    <div class="underlyingDiv">
    <div class="divThatSitsOnTop">This sits on top
    </div><!-- This ends  divThatSitsOnTop-->
    </div><!-- This ends underlyingDiv -->
    Now, I have used "Classes" here, not "IDs." Anything that occurs only once in a given web page may be an ID and not a class. Anything that is used several times in a web page must be a Class. Classes are defined in CSS with a dot before them, IDs with a hash (#).
    Mar 14, 2013 11:06 AM   in reply to Stratusphere_14
    You could save some time & start your project with one of the pre-built CSS layouts that comes with DW?
    Go to File > New > Blank page > HTML > Layouts.
    Choose a layout from the 3rd panel  -- I recommend  "1 column fixed, centered, header and footer."
    Hit Create button.
    Nancy O.
