Gug88
DataGrid Moving rows up and down
Mar 14, 2013 2:01 AM
I have this function to move rows up in a datagrid , yet i am having problems when it comes to move to rows down. I have tried changing the following line to +1 but it dint work any hints please.
            ac.addItemAt(itemToShift,dg.selectedIndex-1);
This is the code
public function up():void
            if(dg.selectedIndex == -1)
                Alert.show("Select the row which you want to up.");
                return;
            if(dg.selectedIndex == 0)return;
            var selectedRowInx : Number = dg.selectedIndex;
            var itemToShift : Object = ac.getItemAt(selectedRowInx) as Object;
            ac.removeItemAt(dg.selectedIndex);
            dg.invalidateDisplayList();
    Mar 14, 2013 6:25 AM   in reply to Gug88
    Try this.
    Get the item you are moving; "MoveObject" and the index "MoveObjectIndex"
    Get the object of the item you are moving the new item after;  "ObjectBefore"
    Then remove the old item. "MoveObjectIndex"
    Refresh the ArrayCollection
    Find the index of the "ObjectBefore"; "ObjectBeforeIndex"
    Then insert the "MoveObject" to the "ObjectBeforeIndex" +1
    Mar 15, 2013 10:59 AM   in reply to Gug88
    Do you have UP and DOWN arrow buttons for moving the item?
    Or, do you have CUT and PASTE buttons?
    Mar 15, 2013 12:49 PM   in reply to Gug88
    Okay.  So, I made the code a little simpler than what I said. With my code, you could have selected a row, clicked a cut button, then selected a another row to past afterwards or whatever.  Here is the code for simply moving the row up and down.
    I added code to catch if the row was at the top or the bottom of the data.  Also, I created two indexes, one for the grid and one for the array collection.  It will probably work with the one index, but I was trying to see if I could do the move on a sorted datagrid, but that is basically pointless.
    protected function moveUpBtn_clickHandler(event:MouseEvent):void
     var upSelectedIndex:int = myDataGrid.selectedIndex;
     // Move Item
     if(upSelectedIndex > -1) {
      if(upSelectedIndex > 0) {
       // Get the selected Object
       var moveObject:Object = myArrayCollection.getItemAt(upSelectedIndex);
       // Get actual Object location if grid is sorted
       var upActualIndex:int = myArrayCollection.getItemIndex(moveObject);
       // Remove selected item at actualIndex
       myArrayCollection.removeItemAt(upActualIndex);
       myArrayCollection.refresh();
       // Move both indexes
       upActualIndex--;
       upSelectedIndex--;
       // insert item at actualIndex
       myDataGrid.dataProvider.addItemAt(moveObject, upActualIndex);
       // select grid at selectedIndex
       myDataGrid.selectedIndex = upSelectedIndex;
      } else {
       Alert.show("Item is currently at the top of the list.", "Move Alert",  Alert.OK, this);
     } else {
      Alert.show("No Item Selected.", "Move Alert",  Alert.OK, this);
    protected function moveDownBtn_clickHandler(event:MouseEvent):void
     var downSelectedIndex:int = myDataGrid.selectedIndex;
     if(downSelectedIndex > -1) {
      // Move Item
      if(downSelectedIndex < myArrayCollection.length -1) {
       var moveObject:Object = myArrayCollection.getItemAt(downSelectedIndex);
       var downActualIndex:int = myArrayCollection.getItemIndex(moveObject);
       myArrayCollection.removeItemAt(downActualIndex);
       downActualIndex++;
       downSelectedIndex++;
       myDataGrid.dataProvider.addItemAt(moveObject, downActualIndex);
       myDataGrid.selectedIndex = downSelectedIndex;
      } else {
       Alert.show("Item is currently at the bottom of the list.", "Move Alert",  Alert.OK, this);
     } else {
    Here is the blog post with the working DataGrid and Source View
    Message was edited by: DeanLoganBH  - Had to set the Down Move to look for the Length of the ArrayCollection -1, because the DataGrid row starts at 0, it is one less than the total length of the ArrayCollection.
