I'm working on a project shot mainly with Canon DSLR footage (1080p, 24fps.) But now I would like to add some footage from a Canon Camcorder recording in AVCHD format. It would seem to make the most sence to shoot at 24fps, or as Canon calls it pf24. The question is, is premiere or media encoder able to interpret the canon footage and do the proper 3-2 pulldown? Or should I record in 30fps (or pf30) and convert the footage to 24 fps in media encoder before adding it to my project? Keep in mind that I can't just shoot everything in 30p because the bulk of the project is already shot at 24p. Also, I am using CS6. Does anyone have experience with this? Thoughts?
PP will remove any pulldown from 30i clips when added to a 24p sequence.
However, PsF doesn't necessarily mean wrapped in a 30i cadence. It just means the full frame was split into two fields. Whether or not pulldown is added is a separate issue. You just need to make sure PP sees the footage as progressive by right clicking on those clips and going to Modify>Interpret Footage...
Having said that, definitely run some tests before you shoot for real.
So from what I'm reading, premiere should be able to automatically convert any footage droped onto the timeline. The problem here is that premiere is unable to read these canon pf24 and pf30 files, all it sees is the 60i container they're wrapped in and reports them as 29.97i. I'm thinking the best option may be to shoot in pf30, do a deinterlace in media encoder just so premiere sees the file correctly (there should be no quality loss since it's actually recorded 30 frames progressive), then when I drop the 30p files onto a 24p timeline premiere should be able to deal with them properly. Thoughts?
Thanks Ann, your link led me to another link in the same series that shows how to get premiere to see pf30 footage as progressive by using the modify/interpret footage dropdown, then under field order choosing no fields progressive.
That does away with the need to run the footage through media encoder. No mention if this works for pf24 however.
I've read that After Effects has an option to do 3:2 pulldown on it's interpret footage dropdown, but premiere does not seem to have this option.
OK, I did some more tests. The interpret footage trick from above works on pf30 footage dropped into a 30p timeline. But when dropped into a 24p timeline camera motion is blurred and choppy.
Also interpret footage doesn't work with pf24 footage at all, again blurred motion and choppyness, weather dropped into a 30p or 24p timeline.
From this it seems that premiere isn't doing any sort of 3:2 pulldown whatsoever. At least not on this ridiculous canon progressive footage wrapped in a interlaced container.
The thing is the pf24 footage looks smooth when played back from the camcorder.
So now I'm at a loss.
OK looks like I found the solution. You have to take the pf24 footage into After Effects and use the interpret footage dropdown there, then just click the guess 3:2 pulldown button. Right click on the file again and choose the make composition from selection. Then render the composition out to a full resolution avi file (1920 x 1080, 23.976fps) and put it in your timeline. The bummer is you have to do this for every file, and the files are large (about 8gb per minute) but since your output choices are limited in after effects, full resolution avi files are the best choice to retain quality. Adobe really needs to add a guess 3:2 pulldown button to premiere's interpret footage dropdown. This was way more difficult than it needed to be. Then again I guess canon created the whole problem in the first place. Thanks a lot canon.
choppy playback during pans or periods of fast motion.
That is more likely a sign of something wrong with your shooting than with the footage. With 24p, you need to take it pans and such slower than with normal video. If you don't, that 'chop' is the result. Nothing you can really do to fix that but reshoot and move the camera slower.
I consider system issues, but I only really noticed the choppy playback on the canon pf24 footage. My system plays back pf30 (after interpreting), 30p, 30i and 24p footage just fine. I think the problem is that premiere is unaware that the pf24 footage is shot at 24fps, and there is no way to manually tell it to do a 3:2 pulldown, like there is in after effects.
The shooting is certainly part of it. I shot it purposly that way so any choppy playback would be more apparent. This is the bottom line as I see it. When played back through the camera the movement is smooth. Playing these same pf24 files in premiere, choppy playback results. Since there is no way to force premiere to do 3:2 pulldown, premiere is playing the duplicate frames (every 5th frame ) that it is supposed to disgaurd resulting in choppy playback. After interpreting in after effects ( with 3:2 pulldown applied ) playback is smooth, matching camera playback. Keep in mind that the choppiness is subtle and could easily be missed if you had little or no camera movent or no fast motion in your files.
Ed you are soo right! PP does not automatically fix the problem by dropping the footage into a 24p AVCHD sequence. If you have CS6 PP and AE you can use easily fix this ugly problem.
Excuse me why I step up on my soapbox - Adobe Premiere Pro development team -- please fix this @$%& problem asap!!!! The PP Interpret footage function is a joke without it!
The best solution I could come up with after investing a ton of time into this is to use AfterEffects inside PP as a filter. Therefore you will not have to duplicate or re-render all your PF24 footage to create true 24p clips. You work with the same source clips throughout the entire process. Here's what you do - 1st create a 24p AVCHD sequence in PP and drop your PF24 clips into it. Now you can select individual clips or the entire sequence of clips and "right click" and select "Replace with AfterEffect Composition". This will export the selected clip(s) into AE. Now you can use the world-famous AE Interpret footage function to remove the pulldown issues. Inside AE right-click the clip - select Interpret footage - select the fielding (in my case it was Upper Field First) - then finally the "magic bullet" - select "Guess 3:2 Pulldown" button. Now when you jump back into PP you will be working with beautiful "TRUE" 24p footage.
All the best!
North America
Asia Pacific
