Hello,
I am having a problem printing borderless with InDesign CS3. When my paper size is set on borderless my photos print very light. If Iremove the borderless setting the photos print fine.
In a effort to correct this problem I downloaded and installed updates for InDesign CS3 now InDesign will not open.
5.0.3 should not have installed after 5.0.4 (that's a problem with the installer), and it may have added problems. First things to try, though, before we get down to uninstalling and reinstalling again, are trashing the prefs (Replace Your Preferences), trying a new user account, and starting with extensions disabled (hold down the Shift key when you boot).
If it comes to reinstalling again, you should probably also run the cleaner tool (CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3) before reinstalling, and make sure you have the correct update which you can download again from http://www.adobe.com/support/downloads/detail.jsp?ftpID=4029
I don't see a smoking gun there, but I'm not as expert at reading the reports as some others are. One thing, though, it indicates that the update is not installed, so you should download and run the update again from the link I posted above.
If it continues to crash after that, post another report.
I just tried to use the CS Cleaner Tool as you suggested. I'm going to need to find my original InDesign CS3 software so I can reinstall it and that could take a while.
I think I am getting in over my head. I will keep you emails and follow your suggestions.
I'll let you know how things turn out.
Thanks very much for your help.
Joe
North America
Asia Pacific
