baxterwalker
Can I make Expert Mode and Full Screen Size my Default Setting PSE 11 ?
Mar 15, 2013 2:16 PM
Tags: #11
Each time I open a new image in ACR and then open image the editing screen reverts to QUICK mode and a smaller screen size.  I then have to click to change it to EXPERT mode and then click to make it full screen.  I never had this problem with PSE 10.
(I am bringing RAW images in from outside and not via Organiser.)
Is there a way to set these defaults?
    Mar 15, 2013 2:19 PM   in reply to baxterwalker
    Elements remember your last closing state, so if you close the editor at guided edit and then reopens it then it will opens it in the guided edit mode.
    If that is not the case then you can go to the preferences (Edit>Preferences) and and then click on the option 'Reset Preferences on next launch'
    Now close your photoshop elements and relaunch it. It will recreate the preferences for you.
    Harshit yadav
    Mar 15, 2013 3:09 PM   in reply to baxterwalker
    Try deleting the prefs. Go to the editor preferences, click this button, and restart the editor:
    Mar 17, 2013 1:35 PM   in reply to baxterwalker
    What version of windows are you using?
    Mar 17, 2013 2:57 PM   in reply to baxterwalker
    The preferences file Adobe Photoshop Elements 11 Prefs.psp should be in:
    C:\Users\Your Name\AppData\Roaming\Adobe\Photoshop Elements\11.0\Editor
    You need to have Show hidden files and folders enabled in the windows 7 folder options.
