plastique@
Button links for subdomains
Mar 16, 2013 5:04 AM
Tags: #as3 #swf #links #action_script_3 #flash_professional #cs6 #subdomain #flash_cs6
Hello,
I have a swf on my website with some links.
The problem is that i have many subdomains.
ex. es.domain.com, it.domain.com
I'm using a delivery network so the same swf file is served on every subdomain.
My buttons have a simple call
navigateURL("www.domain.com/items/category/web");
Is there a way to replace the www with the current subdomain ?
Many Thanks!
    Mar 16, 2013 6:15 AM   in reply to plastique@
    If you're just trying to load an URL however (as in navigate the whole current page to a different URL of any kind what-so-ever) you can do that without any cross domain. Subdomains can only cause issues if you try to load assets from them inside a SWF on a different domain, forcing you to include some cross domain policy.
    Here's an explaination of crossdomain.xml and cross domain policy:
    http://kb2.adobe.com/cps/142/tn_14213.html
    Exactly what error/issue happens?
    Mar 17, 2013 8:08 AM   in reply to plastique@
    Are these swfs served FROM different subdomains or pages load THE SAME swf from the same location and pages themselves are loaded from different subdomains?
    If former - read SWF location in LoaderInfo.url
    If latter:
    Read browser location:
    ExternalInterface.call("window.location.href.toString")
    Then use values in navigateToURL
    Mar 17, 2013 1:16 PM   in reply to plastique@
    www is the default if you are not excplicitly setting the location otherwise. If you want to stay on sub.domain.com then you need to either use relative URLs (e.g. URLRequest('/images/some.jpg')) or specify the full URL (e.g. URLRequest('http://sub.domain.com/images/some.jpg);). Even standard HTML links (e.g. <a href="domain.com/items/web">click me</a>) will fail to stay on a sub.domain.com  URL. You'd need to supply it (e.g. <a href="http://sub.domain.com/items/web">click me</a>).
    Mar 19, 2013 7:25 AM   in reply to plastique@
    In your example you want the "/items/web" folder and you're already inside "/items" so you wouldn't write "/items/web", you'd just write "web/".
    The root of a SWF is the HTML that's hosting the file so all relative linking should be from the HTML and not the SWF location incase that's tripping you up. I assume you're using some type of MVC where sub.domain.com/index.php|aspx is loading the /items controller with the argument /web. If that's the case then the SWF root would actually really be root. If you literally have HTML loading the SWF inside the /items folder (e.g. /items/somefile.html|aspx|php) then your root is already "/items" and you should not re-supply it in requests or yes, you'll get "/items/items/web".
    You can PM me a link if you like.
