Inadequate Date Created Feature in IPTC Panel
Mar 16, 2013 8:44 PM
I am currently having a service digitize about 3,000 of my photos, shot of 35mm film. I am entering IPTC metadata using Photoshop's File Info….
I want to use the Date Created feature. Fortunately, I have the exact calendar day of most of my photos. However, in a few cases, I know only the year and the month, and not the specific day.
Much to my chagrin, I have discovered the Date Created feature doesn't support entering only a year and a month (unless I'm missing something.) I thought it would support, for example: 19860100, for an unknown day in January 1986.
I wonder what archivists do about this. Simply not use the Date Created feature?
I am entering the date in the description too.
Related info:
http://ptforum.photoolsweb.com/ubbthreads.php?ubb=showthreaded&Number= 877
    Mar 17, 2013 10:01 AM   in reply to NY2LA
    If you want the metadata of the date created to be read in Bridge or other browsers I believe you can not just change the IPTC field in File Info.  I tried this and the Date Created was unchanged, even though in IPTC field it was changed.
    I have see posts where you can get a 3 party program to change the Date Created field.
    As far as the day the pictue was shot without a diary don't believe that is possible.  Just pick a number you like and use that for all of them.  If 3rd party re-dating program works with 00 as the day try one and see if Bridge or other browsers works with it before doing 3000.
    Mar 17, 2013 4:52 PM   in reply to NY2LA
    You have to be careful of what different programs call Date Created.  For instance in Bridge Date Created is the date when picture was taken or scanned.  It can not be changed in Bridge.  Windows Explorer lists Date Created but it really is Date FILE Created.  It does not show Date Created.  Do not know what Flickr shows.
    Look at an image in Bridge where the Date Created and Date File Created are different and see what other programs call Date Created.
    In Photoshop I clicked File Info and changed Date Created in the IPTC field.  But looking at the image in Bridge the metadata for Date Created is still the original date even though if you look in File info it has changed..
    Mar 17, 2013 6:59 PM   in reply to NY2LA
    Perhaps it works different on a Mac, but there is no reason for this.
    Here are my screen shots.
    As you can see it changes the date in the IPTC field, but not the metadata field in Bridge.
    Mar 19, 2013 7:16 AM   in reply to NY2LA
    Yes, and I am also repeating what others have reported, to their disgust, that you can not change Date Created in Bridge as this field is set by camera or scanner.
    Mar 19, 2013 1:53 PM   in reply to NY2LA
    That field does have the same name but it is not the actual date created you are amending. You are amending the Photoshop schema not the EXIF schema or the XMP schema
    Mar 19, 2013 2:15 PM   in reply to NY2LA
    Goto file info, select the Advanced Tab and look at the various Schemas. You are only altering the Photoshop Schema.
    Mar 19, 2013 2:46 PM   in reply to NY2LA
    No, it's just a fact that you can not change the actual date of the file within Bridge.
    If you really wanted to change the actual date you would need to use an external program such as ExifTool.
    It just depends on what data you need to have.
    Mar 19, 2013 2:57 PM   in reply to NY2LA
    Yes it does, IPTC uses more than one schema, the Photoshop field for date created is part of IPTC
    Mar 19, 2013 3:02 PM   in reply to Paul Riggott
    You should be able to download some information from here...
    http://www.adobe.com/devnet/xmp.html
    Mar 19, 2013 3:20 PM   in reply to NY2LA
    That's fine. There are various dates involved with a document, so long as you are using the fields that you want to use that's all that counts.
