leedsmein
New NVIDIA Driver issue with Premiere pro
Mar 17, 2013 1:01 PM
Laptop
Windows 7 pro x64
Intel Core i7 2.7ghz
16 gig ram
NVIDIA GTX675MX driver version 314.07 2013.2.18
Hello, I had to update the driver due to premiere stating I had an outdated driver.  After installation everything seemed fine however today when I opened premiere my source and preview windows showed black, no video.  My edits and source files were all still there.  Sound from my clips played but no video.  I have Mercury playback set to hardware.  When I switch it to software the video images return.  Has anyone else had an issue with this driver in Premiere pro and did you find a solution?  I did a search and this seems to be an issue with drivers.  Hope they fix it in the next update. Thanks.
    Mar 17, 2013 2:26 PM   in reply to leedsmein
    If any specific driver causes problems, you might try going to the nVidia site to find out of there is a newer driver to try
    If not, try older drivers to see if one works, such as a 310 version... just NOT a 306 version (I think that is the number of the driver that had major problems)
    Mar 17, 2013 3:25 PM   in reply to leedsmein
    I haven't had any problems with that driver myself, on two machines with two different cards.
    You may have to go into the BIOS and make sure any on-board video is disabled.  You want nVidia to be the only GPU in use.
    Mar 17, 2013 3:26 PM   in reply to leedsmein
    The card I have is not on the Adobe supported list after all.
    Neither are mine.
    Don't expect either Adobe or nVidia to issue 'a fix', because I don't belive there is a problem with the driver, only with your system.
    Do go into the BIOS.
    Mar 17, 2013 4:18 PM   in reply to leedsmein
    Not sure how much performance loss there is with hardware turned off.
    Only 12 times slower or thereabouts with rendering. Which driver are you using?
    Mar 18, 2013 1:35 AM   in reply to leedsmein
    You could try the 314.21 beta driver.
