RonDube
Modifying CS5 graphs in CS6
Mar 17, 2013 4:15 PM
After selecting the graph, I then select data under Object>Graph>Data. The window comes up, but no data - to modify!!
Please HELP!!
    Mar 17, 2013 4:34 PM   in reply to RonDube
    Are you sure that the diagram hasn't been ungrouped?
    Mar 18, 2013 3:51 AM   in reply to RonDube
    You can't attach this here.
    But actually you can also check that yourself. The layer panel will tell you if it's a diagram or not.
    Mar 18, 2013 7:17 AM   in reply to RonDube
    If at any point you saved the CS6 file down to CS5 and seen the message below, then the graph is now not a live graph anymore but has been turned into vector paths.
    If you select the graph and can see
    then you should be able to edit the data.
