Often times I can not select a transition when I place the Selection Tool over it. Instead, it becomes a red arrow pointing either left or right depending on how I select it. I find that I have to zoom in so that I can select it. Is there an easy way to select a transition without having to zoom?
Thanks.
Create a feature request for better edit and transition selection. http://www.adobe.com/go/wish
I get annoyed at this sometimes too. ![]()
StanWelks wrote:
Just curious, was this a well know change that Adobe did as you guys suggested it was a "favor"? Personally, I find it really annoying when just trying to select a transition and not being able to do it without zooming all the way in. Not a big deal, just a bit annoying.
Thanks.
The "\" key allows you to quickly toggle zooming in and out. Most definitely you can grab the transition then.
Kevin Monahan wrote:
Thanks.
Well actually it does not. You have to use the + and - key, or some other keystroke.
I use playhead + alt.
If you hit the \ you get the whole timeline. If you hit it again you are back where you started.
Stephen: I am getting used to these trim tools now but the transitions are a big pita.
Thanks.
Hi Ann,
I set it up by zooming in close enough to grab a transition manually. From that point forward, the \ key will zoom in and out at that level. Does that not work for you?
North America
Asia Pacific
