helen2263
Need help with gradient map
Mar 18, 2013 2:49 AM
Hello All,
Please can someone please advice me how to get the following gradient, I have tried but with no luck I am not good with gradient map!
  • Pierre Courtejoie
    Jan 11, 2006
    Mar 18, 2013 5:23 AM   in reply to helen2263
    Hello!
    What part do you have trouble with? the recreation of the gradient, or how it affects the image?
    In the gradient map editor, you can double-click on the bottom markers (called gradients stops) to change their color, and drag them around to re-create what you see... Click between two markers to add one, drag a gradient stop down to remove it.
    In fact, you do not need the fourth gradient stop, the white one on the right side.
    The top markers control the transparency (in regular gradients, gradient maps are unaffected)
    With such a gradient map, the dark areas of the image will be white, neutrals will be black and light areas will be white.
