In my Window 7 Adobe Design Suite CS6, Bridge doesn't seem to worik. (I had never used it before, but now need it.)
I tried starting Bridge from the EXE file. A flash in the lower task bar of Windows, then nothing. The Task Manager does not show it running either. The Mini-Bridge shows "Click to Launch Bridge," but the time-icon just spins on and on, with no effect. It is the same in all the applications.
I completely reinstalled CS6, but the results are the same.
I tried the Ctrl-Shift-Alt trick to delete the preferences, but I have no idea if it worked or not. Is there another way to remove the preferences?
When you look at the Bridge.exe it should have about 20,282 kb.
Do you by chance have CS2 on your computer? If so look at post #64 on this thread http://forums.adobe.com/thread/1028447?start=40&tstart=0
And, yes, I have CS2 (folder named "Bridge" and CS3 ("Bridge CS3") on my computer, though I only use InDesign with those older suites. All the others were deleted.
As a Mac user I leave the Windows details to Curt but if you have deleted applications instead of official uninstalling then that could lead to problems. But even uninstall is not deleting all files and settings. On a Mac there are always several files in user libraries that don't get uninstalled. Therefor you have to use the Clean tool for CS suite.
If you want to start fresh then that might be your goal. Uninstall everything and use the Adobe Clean Tool. Then if you do have the need for ID CS2 (must be a particular reason because you also have ID in CS6) and then reinstall CS6 again.
Also be sure to first deactivate and delete settings before uninstalling and of course have your Adobe ID and serial number at hand ![]()
Here is the part about the cleaner tool, first read the instructions carefully:
I was out of the country and so did not answer earlier. Yes, I did make a blank directory under Roaming called "Bridge CS2", rebooted, and nothing happened. So I unisntalled CS2, which I never use anyway. Still no change.
Incidentally, both Abobe Bridge CS6 and Adobe Bridge CS6 (64 bit) were installed with the Suite. I tried them both, to no avail.
North America
Asia Pacific
