fixing line break with hanging indent, tabs
Mar 18, 2013 3:07 PM
Tags: #cs5 #nested_style #mac_os_10.7.5 #hanging_indent
Issue: InDesign sometimes squeezes the first line wordspacing instead of moving content to the next line (see red arrows) with hanging indent and nested style controlled by tabs in TOC. I believe this has something to do with the tabs. Changing the Justification settings (Adobe Paragraph Composer, Adobe Single-line Composer; and Minimum/Maximum Word/Letter Spacing) does not help.
The current workaround is to insert a soft return at the end of the first line, but I'd like to avoid. Is there a better way to set this up?
1. Paragraph style is set for hanging indent (left indent: 72 pt, first line indent: -72pt). This style also includes two tab positions.
2. Number style (TOC #) is a character style.
3. A nested style controls the position of the TOC number via two tab characters, which correspond to tab locations set in the paragraph style -- a right align tab for the number, and a left align tab for the text.
Thanks in advance!
InDesign CS5, Mac OS 10.7.5.
    Mar 18, 2013 3:16 PM   in reply to jennifer scrivner
    I'm not certain it's pertinent, but waht method have you used to drop the first tab and digit below the baseline?
    Mar 18, 2013 4:05 PM   in reply to jennifer scrivner
    What happens if you don't use baseline shift?
    Can you show us the justificattion settings? Is hyphenation allowed?
