Is it possible via javascript/jQuery to select an image option (see below) and then have the image associated with the <option> show next to the <select> tag?
<select name="images" id="images">
<option>Select Image</option>
<option value="one.jpg">one.jpg</option>
<option value="two.jpg">two.jpg</option>
<option value="three.jpg">three.jpg</option>
<option value="four.jpg">four.jpg</option>
<option value="five".jpg>five.jpg</option>
</select>
<img src="http://www.DomainName/imageOptions/nameOfImage.jpg" width="200" height="200" alt="" />
I could probably do it with php by getting the option value but that means I'd have to submit the page first, which I'm trying to avoid. javascipt might be able to do this onclick?
Cheers
Os
Hummm...the only issue I see is that I have about 100 images. Does that mean I have to create 100 variables?
var ddData = [
text: "Facebook",
value: 1,
selected: false,
description: "Description with Facebook",
imageSrc: "http://dl.dropbox.com/u/40036711/Images/facebook-icon-32.png"
text: "Twitter",
value: 2,
selected: false,
description: "Description with Twitter",
imageSrc: "http://dl.dropbox.com/u/40036711/Images/twitter-icon-32.png"
text: "LinkedIn",
value: 3,
selected: true,
description: "Description with LinkedIn",
imageSrc: "http://dl.dropbox.com/u/40036711/Images/linkedin-icon-32.png"
text: "Foursquare",
value: 4,
selected: false,
description: "Description with Foursquare",
imageSrc: "http://dl.dropbox.com/u/40036711/Images/foursquare-icon-32.png"
I could use the html variation and grab all the necessary data from a database. However I need the image to be outside of the <option> tag because if I have 100 images at 200px high thats going to be a lot of scrolling to go through.
<select id="demo-htmlselect">
<option value="0" data-imagesrc="http://dl.dropbox.com/u/40036711/Images/facebook-icon-32.png"
data-description="Description with Facebook">Facebook</option>
<option value="1" data-imagesrc="http://dl.dropbox.com/u/40036711/Images/twitter-icon-32.png"
data-description="Description with Twitter">Twitter</option>
<option value="2" selected="selected" data-imagesrc="http://dl.dropbox.com/u/40036711/Images/linkedin-icon-32.png"
data-description="Description with LinkedIn">LinkedIn</option>
<option value="3" data-imagesrc="http://dl.dropbox.com/u/40036711/Images/foursquare-icon-32.png"
data-description="Description with Foursquare">Foursquare</option>
</select>
I hear you.
I remember bookmarking a SO thread for this a while ago. Here it is: http://stackoverflow.com/questions/2663552/how-to-display-image-when-c lick-the-select-option-using-jquery-css
I was investigating the possibilty of perhaps moving the image out of the <option> tag using a <span> with abosolute positioning however I can't even get the basics to work, what gives. I've coppied the html version, downloaded the ddslick.js and hooked it all up but no images show. Checked images are at the correct url location as in the demo.
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js"></script>
<script type="text/javascript" src="ddslick.js"></script>
$('#demo-htmlselect').ddslick({
onSelected: function(selectedData){
//callback function: do something with selectedData;
</script>
</select>
Sudarshan Thiagarajan wrote:
What is showing up with the code you already have? At least a simple plain dropdown or not that too?
The dropdown is showing but no images. However your other suggestion looks better:
Have you managed to get it working? Nothing changes for me when I use this set up:
$(function() {
$("select[name=payment]").bind("change", function() {
$("#payment img").attr('src', $(this).val().toLowerCase() + ".gif");
}).change();
I'm assuming 'paypal.gif' below should change to 'bank.gif' when the option 'Bank' is chosen?
<div id="payment"><img src="paypal.gif" alt="paypal" /></div>
<form action="image_in_folder.php" method="post">
<select name="payment">
<option value="">Please Select</option>
<option value="Paypal">Paypal</option>
<option value="Bank">Bank</option>
</select>
</form>
Gawd blimey, I had to hunt high and low and do a lot of piecing together of other peoples jQuery that failed, but finally arrived at the solution.
$(document).ready(function(){
$('#nameOfselectTag').change(function(){
var selected_value = $(this).val();
$('.showImage').html('<img src="'+selected_value+'" alt="" />');
Hi Sudarshan
Just to elaborate the image gets written to an independent <div> - <div class="showImage"></div>, which can be positioned anywhere on the page.
North America
Asia Pacific
