So what i would like to achieve is in my estimator, in the "Choice of coffin" section, in order for the Additional services' (drop down menu) to calculate, the radio button (above) for 'Simple Basic coffin' has to be selected. Basically those additional services are only available if the basic simple coffin is chosen.
I just cant get my head around how to restrict that drop down calculation from happening if simple basic not chosen.
http://www.milesmemorials.com/estimator.html
Any help appreciated!
Try this - add the following bold code to your javascript in the indicated location -
cemetery_fee = Number(document.catwebformform22057.CAT_Custom_76931.value)
zz=document.getElementById('CAT_Custom_76926_0').checked==true;if(zz) { document.getElementById('basicServices').style.display='block'; } else { document.getElementById('basicServices').style.display='none'; };
Then change this -
<select name="CAT_Custom_00010"
to this -
<span id="basicServices"><select name="CAT_Custom_00010"
and this -
<option value="545" >Limousine,Chapel visiting, Choice of date & time (£545)</option>
</select></td>
to this -
</select></span></td>
Finally, add this to your CSS -
#basicServices {
display:none;
See if that does what you want.
Excellent that works really well. Thank you!
Im trying created a php file (estimate-to-email.php) to go with this page so that all the information that is selected including the values of those selections is sent in an email. BUT! Im not sure how to collect the informations in the sections that only calculate if chosen for example - The 'Additional services' just created, 'Burial' (plus all the info within this section) and 'Cremation' (again plus all the info within this section)?
This is what ive created so far. (ive left out the sections that im not sure about)
<?php
if(!isset($_POST['submit']))
//This page should not be accessed directly. Need to submit the form.
echo "error; you need to submit the form!";
$CAT_Custom_76922 = $_POST['CAT_Custom_76922'];
$CAT_Custom_00000 = $_POST['CAT_Custom_00000'];
$CAT_Custom_76926 = $_POST['CAT_Custom_76926'];
$CAT_Custom_76924 = $_POST['CAT_Custom_76924'];
$CAT_Custom_76927 = $_POST['CAT_Custom_76927'];
$FirstName = $_POST['FirstName'];
$LastName = $_POST['LastName'];
$EmailAddress= $_POST['EmailAddress'];
$HomeAddress = $_POST['HomeAddress'];
$HomeCity = $_POST['HomeCity'];
$HomeState = $_POST['HomeState'];
$HomeZip = $_POST['HomeZip'];
$HomeCountry = $_POST['HomeCountry'];
$HomePhone = $_POST['HomePhone'];
$CellPhone = $_POST['CellPhone'];
//Validate first
if(empty($CAT_Custom_76922)||empty($CAT_Custom_00000)||empty($CAT_Cust om_76926)||empty($CAT_Custom_76924)||empty($CAT_Custom_76927)||empty($ FirstName)||empty($LastName)||empty($EmailAddress)||empty($HomeAddress )|empty($HomeCity)|empty($HomeState)|empty($HomeZip)|empty($HomeCountr y)|empty($HomePhone)||empty($CellPhone))
echo "Please make sure all fields are filled in!";
exit;
if(IsInjected($EmailAddress))
echo "Bad email value!";
exit;
$email_from = '$EmailAddress';//<== update the email address
$email_subject = "Estimate from M&D website";
$email_body .= "Name: $FirstName.\n";
$email_body .= "Surname: $LastName.\n";
$email_body .= "Address: $HomeAddress.\n";
$email_body .= "City: $HomeCity.\n";
$email_body .= "County: $HomeState.\n";
$email_body .= "Postcode: $HomeZip.\n";
$email_body .= "Country: $HomeCountry.\n";
$email_body .= "Phone: $HomePhone.\n";
$email_body .= "Mob: $CellPhone.\n";
$email_body .= "Removal milage: $CAT_Custom_76922.\n";
$email_body .= "Viewing: $CAT_Custom_00000.\n";
$email_body .= "Coffin: $CAT_Custom_76926.\n";
$email_body .= "Route: $CAT_Custom_76924.\n";
$email_body .= "Limousines: $CAT_Custom_76927.\n";
$to = "Ness_Rob@yahoo.com";//<== update the email address
$headers = 'From: '.$EmailAddress."\r\n";
$headers .='Reply-To:'.$EmailAddress."\r\n";
//Send the email!
mail($to,$email_subject,$email_body,$headers);
//done. redirect to payment page.
header('Location: thankyou_estimate.html');
// Function to validate against any email injection attempts
function IsInjected($str)
$injections = array('(\n+)',
'(\r+)',
'(\t+)',
'(%0A+)',
'(%0D+)',
'(%08+)',
'(%09+)'
$inject = join('|', $injections);
$inject = "/$inject/i";
if(preg_match($inject,$str))
return true;
else
return false;
North America
Asia Pacific
