richardn
Photoshop CS6 zoom percentage
Mar 19, 2013 5:14 AM
Tags: #photoshop #default #value #percentage #cs6 #zoom #percent
Hi there,
Does anyone know if there is a way to set a default zoom percentage value in Photoshop CS6?
I would like to set this to 31.5%.
A bit of a strange value I know, but I've found that this value gives me an image on the screen that is the same size as what I get out of the printer.
It would be great if I could do this, as it's a bit of a bind having to type in 31.5 over and over again in the Navigator.
Apologies if this is covered elsewhere.  If it is I haven't been able to find it.
Richard.
  • JJMack
    Jan 9, 2006
    Mar 19, 2013 5:40 AM   in reply to richardn
    It depends if your on the Cloud or not. Adobe has taken that ability away from their cloud users.
    If your not on the cloud its easy.  First you need to know or calculate your display's DPI resolution and set it into your Photoshop's preferences display resolution.
    Your image print size depends on the DPI resolution it is printed at.  You image has a current Print size it is its current DPI resolution setting that determines print size simple math image pixel width/dpi by image pixel height/dpi.
    Next to need to create an action or script to do a single Photoshop step menu View>Print Size.
    To have it work automatically you need to enable the Script Event Manager and set an open document event to run your View Print Size action or script.
    Paul Riggott script found in the tread http://forums.adobe.com/message/4914063#4914063 comes close for cloud users I don't think he was able write a perfect script to provide cloud users with a solution.
  • JJMack
    Jan 9, 2006
    Mar 19, 2013 8:16 AM   in reply to richardn
    Seem you need a simpler editor then Photoshop or need to learn a bit about the software you have.
    For this is not overly complicated when it comes to Photoshop.
    If you want to automate something using Photoshop you need an Action, Script or both.
    If you want something to be automatically automated when you open a document you need that event to trigger the automation you want to happen.
    If you want your image to be displayed print size on your screen what needs to be known is the print size, the displays resolution and the images pixel size.   Knowing these sizes one can figure out the number of pixels that the imaged need to be displayed with on the display and knowing images pixel size it can be scaled for the display resolution. All image on you system most likely will not be set to 300dpi resolution. Images need to be scaled according to their resolution.
    Photoshop make it very easy to record Action.  The action Palette palette is a full blown action editor.
    Photoshop menu File>Scripts>Script Event Manager make it easy to trigger automation for given events.
    Photoshop knows image pixel size, print resolution therefor can calculate print size.  However  Apple's and Microsoft's operating systems do not know or store your displays resolution and you display hardware does not report pixel resolution to you computer. That piece of the equation is missing you need to set that for Photoshop then and only then can Photoshop calculate the correct View Print Size and scale the image accordingly.
  • JJMack
    Jan 9, 2006
    Mar 19, 2013 8:39 AM   in reply to richardn
    The zoom percentage needed depends on the images resolution. Its what the image resolution is that determines print size.....
    Its simple math (Image Pixel Width Number of)/(Print DPI) = Print Width and  (Image Pixel Height Number of)/(Print DPI) = Print Height
    It Also seems that Adobe want to remove View Print Size as Phoshop continues on its down hill slide.
    richardn wrote:
    I'm always learning, I learn something every day.
    It is quite instructive to click on Image/image size.  In bottom uncheck "resample image" (which adds or subracts pixels).  The change the resolution  and see how image size changes and file size stays the same.  This is what JJ was refering to.  If resample image is "on" the file size changes and image size stays the same.  THey are all interelated.
    And yes, the more you learn the more you see you don't know much.  That is why there is an old expression "ignorance is bliss".  No reflection on you, just an observation.
    Sep 23, 2013 8:55 AM   in reply to richardn
    Hi Richard,
    Here is how you do it step-by-step.
    I needed a keyboard shortcut to return to my favorite zoom level after zooming out for an overview when editing images. And so I decided to make a small tutorial about it, for others in a similar situation:
    http://photography-berlin.blogspot.de/2013/09/photoshop-cs6-custom-zoo m-percentage.html
    I hope you find it useful.
    Cheers
    Lars
