How can I get RoboHelp to recognize my FrameMaker installation?
Mar 19, 2013 11:40 AM
I have Technical Suite 3.5 installed and several RoboHelp projects linked to FrameMaker books.
The Frame books were created in FrameMaker 10. I then upgraded to Technical Suite 3.5, then later upgraded my FrameMaker to 11.
All was well, RoboHelp continued to update from the Frame book files.
Then last week my hard disk crashed. IT provided a new disk, installed the Technical Suite and FrameMaker 11, but now when I open the RoboHelp projects and try to update them, RoboHelp displays an error message that says "Adobe FrameMaker 10 is not installed. No FrameMaker documents can be updated."
When I try to relink the project to FrameMaker (File | Link), I get a similar message:  "This operation cannot be completed without FrameMaker 10. Install FrameMaker 10 and try again."
How can I get RoboHelp to recognize my FrameMaker 11 installation, which it used to do prior to the crash and reinstallation?
Thanks.
Jerry
    Mar 19, 2013 12:19 PM   in reply to Jerry_F_at_RedSeal
    When you upgraded to FM11, was that part of TCS or a standalone version?
    There's a dll that links FM and RH that normally gets installed & registered. That's what adds the RH menu to FM and offers the linking function in RH.
    I'd make sure that you've got TCS4 installed.
    Mar 19, 2013 1:28 PM   in reply to Jerry_F_at_RedSeal
    Nope, that won't work - you need the TCS4 flavour of FM to make linking work. Without it, all you can do is import FM content into RH.
    Mar 19, 2013 1:53 PM   in reply to Jerry_F_at_RedSeal
    Just curious, but why would you have done a point upgrade of FM when you had the suite?
    Mar 19, 2013 2:16 PM   in reply to Jerry_F_at_RedSeal
    In a crunch, I would go into your existing RH project, export the settings (the .isf file) & set up a brand spanking new RH project, import the settings.isf, and then import your FM content. Check the Conversion Settings to ensure that stuff is coming over the way you want and tweak as needed. Generate the help you need & you're done (for now).
