can't connect to server by Adobe Drive
Mar 19, 2013 1:31 PM
Tags: #error #adobe #log #drive
I can connect to the server by web portor but every time when I try to connect by using Adobe Drive, it will show this errors:
sometimes I got this one:
      com.adobe.drive.connector.api.exception.PermissionDeniedException:Ope ration not  allowed.
     com.adobe.drive.connector.api.exception.RemoteIOException: Unable to complete request to remote server
Meanwhile, the log can't be accessed...
could someone help me please?
thank you very much!
Liang
    Mar 19, 2013 4:26 PM   in reply to liangGenus
    What digital asset management system are you using in your workflow and what connector are you choosing in the Adobe Drive Connect UI?
    Mar 25, 2014 1:58 PM   in reply to Laurel Zimmer
    I am having a same issue. " The server could not be connected"  I am using Adobe Drive 5 and AEM DAM?  I am trying to connect using SSL. I can connect via web browser but not using adobe drive.
    Thank you in advance
    Mar 28, 2014 12:19 AM   in reply to naranmalla
    I think the problem is that the exact protocol you enter in the Drive UI (e.g. https://yourserver/path) is never transferred to the ConnectHandler implemented by the connector you are using. Instead, the handler will get something like aem://yourserver/path and probably try connecting via http:// only. The only option I found was having a http:// endpoint, which redirects to the https:// port instead. Then, it seems to work.
