Bubday
Imported AVI has video stutters and leaves remnants/artifacts of motion in both preview and export.
Mar 19, 2013 8:21 PM
Tags: #avi #export #playback #preview
My imported .avi video leaves traces of the motion occuring on-screen as it plays, both in the preview and when I export it. I know I've seen this before, but I can't figure out what it's actually called.
The video is fine when played outside of Premiere, but after importing it, these stutters occur regularly throughout the video. They are consistent, in that they happen at the same locations every time. I've been searching for a while now for a way to resolve this issue. I've mucked with a bunch of settings, but without knowing what this is and why it's happening exactly, I can't seem to fix it.
One thing I have discovered is that the video "appears to have dropped frames". I tried looking into this as a lead, but what I saw didn't look like what I'm experiencing. I could be wrong on this.
    Mar 19, 2013 9:09 PM   in reply to Bubday
    Welcome to the forum.
    What are the exact specs. of you AVI file?
    For more background, see this article: http://forums.adobe.com/thread/440037?tstart=0
    It is likely a CODEC issue, and knowing what is inside that AVI wrapper is likely the key to the puzzle.
    Mar 20, 2013 8:18 AM   in reply to Bubday
    As far as I know... that codec is used for screen capture, such as gameplay... is that what you are doing?
    Techsmith codec http://forums.adobe.com/message/3692768
    -and http://forums.adobe.com/thread/1046914?tstart=0
    Mar 20, 2013 8:38 AM   in reply to Bubday
    In addition to the links that John T. has provided, this article might be useful too: http://forums.adobe.com/message/3601973#3601973
    Though he commented on an earlier version of PrPro, Jeff Bellune's tips might prove useful for dealing with the TechSmith CODEC's. See all links to Jeff's comments and tutorials.
    Good luck and thank you for that information.
    Mar 21, 2013 12:48 PM   in reply to Bubday
    Do your sequence settings in Pr match the properties of the source video from Camtasia?  If you play the Camtasia clip in the Source Monitor, what happens?
    I just imported a 30-minute Camtasia tutorial video that's 1280x720 @ 15 fps into CS6 and I don't get any of the issues that you are seeing.  I added it to a matching sequence.  My video is full 32-bit color, but yours looks like it may have invited producing it at less than that.  What Camtasia production settings did you use?  How did you configure the Techsmith codec for production from Camtasia?
    Jeff
