superdubes2006
Why are my video and audio desyncing?
Mar 20, 2013 5:57 PM
I have an mp4 file that I want to edit in Premiere Elements 11, but the audio and the video won't sync up in the program properly. If I watch the video in Windows Media Player it's fine, but when it's in Premiere and I'm watching the preview as I try to edit things the video is seconds ahead of the audio. What is causing this and how do I fix it?
I'm sorry if this isn't the place to ask this kind of question, but I've been searching for a while for the cause of this and I have no idea what's causing it or how to fix it. If you need more information I'll gladly supply it.
    Mar 20, 2013 6:14 PM   in reply to superdubes2006
    I am having a similar issue with PE9 (have not upgraded as I had just got 9 when I built this system and now 11 is out).
    I capture videos as mpg and then convert to avi with PE before I do my edits. This worked before but now when I try it, I lose the AV sync in the avi. Also see the same if I watch the video in PE.
    I have tried many different project settings but all have the same result.
    I am starting to consider a different video edit suite if I can't get a result from the forum.
    Mar 20, 2013 11:13 PM   in reply to superdubes2006
    OK, I am having the EXACT same issue and it is driving  me crazy. When I play in Window Media Player everything is fine but as soon as I play in Premiere everything is out of sync. I have a bunch of files ripped in the same format but only one (that I know of) is having this issue and it seemed to have come out of nowhere. These are my master files and  I can't edit them due to the syncing issue. Please help.
    Mar 21, 2013 5:18 AM   in reply to mbriddle
    As Superdude says, it often has to do with the characteristics of the source vvideo itself, how well it matches your project settings and if you computer is able to keep up with the video playback.
    In version 11, the project will set up automatically, based on the first clip you add to your timeline. In prior versions, you have to set up your project manually. Also, in versions prior to version 11, there is no real support for non-camcorder sources, like smartphone and iPad/iPod/iPhone footage.
