Hi I have been trying to volume serialize photoshop elements. For this I am trying to register my adobe ID with the the following command in command prompt..
Please help me if the leid is correct. I have tried the same command for adobe photoshop CS6 it worked great for me.
Help me with whats going wrong in this case?
adobe_prtk.exe --tool=Serialize --leid=PhotoshopElements-EMT11-Win-GM --serial=xxxx-xxxx-xxxx-xxxx-xxxx-xxxx --adobeid=xxxx@company.com
Return code = 14
The return code is explained in the following website.
http://www.symantec.com/connect/articles/windows-system-error-codes-ex it-codes-description
| 14 | Not enough storage is available to complete this operation. |
PSE 11 win is an msi installer unlike that of Ps CS6.
Also, before I can help with you want to do, I'd please like to know what you mean by "volume serialize elements 11".
Do you mean that you want to serialize pse11 with a volume serial key. If yes, it'll be the same as serializing your application with a retail key or any other type of a serial number.
If you mean to serialize your app installations on multiple machines, you could again use the same serial number on all the machines. Adobe id/serial number association doens't work on pse11 as it does on Ps CS6 as they're on different versions of provisioning/licensing.
thanks.
~ Shefali
North America
Asia Pacific
