Kernel panic rendering AVCHD footage in Encore CS5 or CS6
Mar 21, 2013 11:01 AM
I have an early 2008 Mac Pro running CS6 and 10.8.2. My usual workflow is burning two hour multi-cam live performances to DVD. Usually this is two cameras of DV, one camera of AVCHD, all in a DV timeline.
Lately I've been trying to burn DV timelines of nothing but AVCHD footage, and somewhere through the rendering process I always get a kernel panic. This happens with different projects, footage from different cameras (I'm using a Panasonic AG-AC130 or HMC40), whether I'm using Encore CS5 or CS6. The projects never finish. It seems to get 50-75% through rendering video before crashing. Rendering these projects on my MacBook Pro work just fine (though much slower). Timelines where it's not 100% AVCHD are still working fine.
I had began having kernel panics unrelated to Encore, but traced this back to a heat issue. It's an old machine after all. After installing smcFanControl, this problem has gone away. I don't normally burn timelines of nothing but AVCHD, but I'm certain there was a time in the past I was able to burn these without issue. I monitor my system temperature during rendering and I'm somewhat confident that's not what's crashing the system.
The top part of my latest crash report is listed below. Can anyone help me figure out what's going on?
Thu Mar 21 02:32:47 2013
panic(cpu 6 caller 0xffffff800fe9db1b): "TLB invalidation IPI timeout: " "CPU(s) failed to respond to interrupts, unresponsive CPU bitmap: 0x1, NMIPI acks: orig: 0x0, now: 0x0"@/SourceCache/xnu/xnu-2050.18.24/osfmk/x86_64/pmap.c:2337
Backtrace (CPU 6), Frame : Return Address
0xffffff8101e53c20 : 0xffffff800fe1d626
0xffffff8101e53c90 : 0xffffff800fe9db1b
0xffffff8101e53d10 : 0xffffff800fea2330
0xffffff8101e53dd0 : 0xffffff800fea2b65
0xffffff8101e53e20 : 0xffffff800fe66a1c
0xffffff8101e53f10 : 0xffffff800fe6a8f0
0xffffff8101e53f40 : 0xffffff800fe18aea
0xffffff8101e53f70 : 0xffffff800fea5b16
0xffffff8101e53fb0 : 0xffffff800feced53
BSD process name corresponding to current thread: PProHeadless
Mac OS version:
12C60
Kernel version:
Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
Kernel UUID: 69A5853F-375A-3EF4-9247-478FD0247333
Kernel slide:     0x000000000fc00000
Kernel text base: 0xffffff800fe00000
System model name: MacPro3,1 (Mac-F42C88C8)
System uptime in nanoseconds: 1380749415118119
last loaded kext at 1365787386464065: com.apple.filesystems.afpfs    10.0 (addr 0xffffff7f9262e000, size 348160)
last unloaded kext at 1360973799296735: com.apple.driver.AppleUSBEthernetHost    2.3.6 (addr 0xffffff7f9260b000, size 20480)
    Mar 21, 2013 11:18 AM   in reply to ZachRosing
    What is the "rendering process"? Are you transcoding in Encore? Is this the Encore build?
    If you are letting Encore do the transcode as part of the build, use "transcode now" to see if it is the transcode or a later part of the build process.
    This suggests it is a dynamic link issue. As an alternative, that most users prefer for HD to SD exports, Export MPEG2-DVD from Premiere and bring this into Encore.
    Mar 21, 2013 11:29 AM   in reply to ZachRosing
    Yes, the "automatic" setting is very nice. A large percentage of the DL problems reported involve HD to SD downrezzing.
    You describe a difference in workflow where the older projects were mixed types (SD/HD?), and I assume were in SD sequences. Are the new ones HD sequences in PR?
    I agree all of these options should work.
    Mar 21, 2013 11:45 AM   in reply to ZachRosing
    I think that is good troubleshooting. Are you saying that it is the exact same sequence, but with only the one camera selected? I'd look for a gap - audio or video.
    Did the direct export succeed? Yes, a failure there would point to a problem in the sequence.
    Mar 21, 2013 11:55 AM   in reply to ZachRosing
    Is there something about that sequence that does not like changing the cameras. As next test, I would just set up the pure HD cam in the same sequence presets and see if that exports.
    Mar 21, 2013 12:36 PM   in reply to ZachRosing
    After a not-too-intense Bing search, the particular panic you're getting seems to be an indication of:
    1. Your Mac Pro is dying.
    2. Bad drivers in combo with an unforgiving OS.
    I don't have any easy advice for number 1.  If it is still a heat issue, you may need to redo the thermal paste on the CPU and blow the dust out of the heat sink.  If it's a deeper problem than that, some serious repair work up to and including replacement may be required.  Either way, it will be a painful fix.  For number 2, try updating your graphics card drivers (which card do you have?) and/or going back to 10.6.x or Lion 10.7.x and see if things improve.
    Jeff
    EDIT: Although Encore and Premiere Pro have their share of bugs, a lot of times they expose weaknesses in a system because of how much they tax all of the hardware and software.
    Mar 22, 2013 4:06 AM   in reply to ZachRosing
    I entered the phrase, "CPU(s) failed to respond to interrupts, unresponsive CPU bitmap" (without quotes) into a Bing search and it was an Apple-related hit on the first page that initially mentioned it.  I found other users on pages 2 and/or 3 that also had critical hardware problems.  Several more had driver issues causing the error.
    Jeff
