Hello
I'm on a Mac 10.8.2 w/ CS6 13.0
I've tried to follow videos and tutorial examples for this process, however I must be missing one or two items...maybe in my set up?
This is one of the tutorials that seems very straight forward(except for a couple typo's) but when I try it, I'm told the file could not be copied to clipboard because it's too large...however it does appear to paste the car over the bottom photo? Or did it?
"First open one of the shots in PhotoShop and select the entire image by pressing Ctrl-A, then cut or copy the image into the clipboard (Ctrl-X or Ctrl-C, either will do the trick), now close this image ... without saving ! Very important, we don't want to change the original image file, you never know you might need it again in the future.
Now create a new document (Ctrl-N) and just click 'OK', no need to change any of the settings, they are set to the content of the clipboard anyway so I can leave them 'as is'. Once the blank document is there hit the Ctrl-V to paste the first image into place. Time to open the second exposure, again Ctrl-A to select the entire shot, cut or copy the image (Ctrl-X or Ctrl-C) and close this file again (Ctrl-W)... do NOT safe the changes to keep the original image intact !
With this second image closed again I am automatically returned to my new document that already contains my first exposure, just hit Ctrl-C to paste the second exposure on top of this one and I'm halfway done already. The order of these shots isn't really that important, you will be exposing parts of one shot into the second one, which one lies below doesn't matter anyway."
Let's say the screen shot below is workable, if not I'll do it the correct way BUT how do I make the brillant layer masking work from here. Everything I've seen says to select the mask, then select the brush, then type of brush, make sure white is the foreground and black is background and just paint. When I paint nothing happens to my images?
Then I've tried going to File>Scripts>Import as Stacks and this seems to bring them in but w/ transparent layers underneath, why?
chad
Northfeather wrote:
Hello
Hi, first thing to do is update Photoshop. You should be on at least 13.0.1 which fixed many bugs. There are newer updates, but as time goes on, more and more things which worked in 13.0.1 are being reported as broken in the current versions 13.0.4 and 13.1.2. My choice is to stick with 13.0.1 on OS X.
Your screenshot shows Background layer targeted. Anything you paint on that will be hidden by the higher layers.
You have no mask in which to paint. Target the top layer then click the Add Layer Mask at bottom of Layers panel to add a white mask to the layer. White in a mask makes the respective pixels of a layer be fully opaque, black makes pixels fully transparent and grays create partial transparency. Paint with black to mask out parts of the layer and reveal the underlying layer.
chad
I guess you mean Load Files Into Stack. It normally creates only one layer per imported file. How many image layers and how many transparent layers are created when you load the two car files into a stack?
I think that when you say "this seems to bring them in but w/ transparent layers underneath" you mean that there is a transparent border around some images in a stack, rather than additional wholly transparent layers are being created.
If so, then that'll be because your images are different sizes and Photoshop is correctly maintaining the images and not stretching and distorting each of them to cover an entire layer.
Hello Conroy
Based on your insight it's clear that you're very knowledable w/ CS6...so I'd like to ask if you wouldn't mind showing how you would achieve creating a new background based on this screen shot. My ways are obviously fouled up from the start. The two images in the center are the ones to work with.
If this is too much I understand...I'm just trying to figure it out!
Oh, ok, that makes sense. That would be correct.
This is a shot of the two photos uploaded via the "Load Files into Stack" premise.
I've aligned the photos and lowered the opacity for better viewing.
What is the best way to extract the car and front grass?
This is the next step that I seem to be doing wrong...Please help?
I see that and understand that, however, how did you do it?
What color was your mask when you started, white...like mine shows? If so, why is it that when I choose the brush and paint nothing changes?
Surely something on my end is on or off that should not be?
Ok, I had to hit the X button to change the black to foreground and vice versa. I get it now. Thank ya kindly!
Would the quick selection tool be a better way to create this image?
Yes, it certainly would be a better way to start the mask. Also, after creating an initial mask with Quick Selection Tool, right-click the mask thumbnail to see a menu containing the Refine Mask command (also available from Properties panel) which can improve the edges in the mask.
The layer is a Solid Fill Layer. It is defined parametrically rather than as pixels. The warning is telling you that it must be rasterized, i.e. pixelized, in order for the Brush Tool to be applied to it.
However, I think you intended to paint in the mask, so you'll need to click the mask thumbnail to target it instead of the actual layer. A white border is seen around the corners of the thumbnail of the current target.
North America
Asia Pacific
