debaniehael
Adobe Premiere CS6 APPCRASH Fault Module Name:dvamarshal.dll
Mar 21, 2013 3:32 PM
Tags: #adobe #premiere #cs6 #fault #appcrash #dvamarshal.dll
Hi, I have successfully downloaded and used a few CS6 programs in my new Creative Cloud membership, i.e. Photoshop, Flash, Bridge.
However, I've downloaded and installed and updated, twice, Adobe Premiere CS6. I did uninstall it in between installs.
The program won't open. The error message I keep getting is:
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    ADOBE PREMIERE PRO.EXE
  Application Version:    6.0.3.0
  Application Timestamp:    505748bf
  Fault Module Name:    dvamarshal.dll
  Fault Module Version:    6.0.3.1
  Fault Module Timestamp:    505737ee
  Exception Code:    c0000005
  Exception Offset:    0000000000030ff1
  OS Version:    6.1.7601.2.1.0.768.3
  Locale ID:    1033
  Additional Information 1:    bc8d
  Additional Information 2:    bc8dea4e9dd9b75bfdb3ece306df51b9
  Additional Information 3:    a1f5
  Additional Information 4:    a1f5d345bd6ec37be171cb28c9fbe7f4
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
My computer is an HP Envy 15 Notebook PC running Windows 7 Home Premium.
Processor: Intel Core i7-3610QM 2.30GHz
8GB RAM
64 bit OS
Any suggestions on how to correct this? I don't want to go to a full computer reformat if there is a simpler solution since I just did one recently. Is there anything I can update or download as a patch, perhaps to fix this?
Thanks for any advice! I appreciate your time and looking into this.
    Mar 21, 2013 3:34 PM   in reply to debaniehael
    Are you updated to Premiere Pro CS6 (6.0.3)?
    Mar 21, 2013 4:18 PM   in reply to debaniehael
    >Intel HD Graphics 4000 and Radeon HD 7750M.
    First, do not use Windows Update... you must go to the vendor web site and check
    Second, you need to tell your computer to use your more powerful graphics adapter... the Radeon
    Dual video laptop problems
    -http://helpx.adobe.com/premiere-pro/kb/error---preludevideo-play-modul es.html
    -http://forums.adobe.com/thread/1001579
    -Use BIOS http://forums.adobe.com/thread/1019004?tstart=0
    -link to why http://forums.adobe.com/message/4685328
    -http://www.anandtech.com/show/4839/mobile-gpu-faceoff-amd-dynamic-swit chable-graphics-vs-nvidia-optimus-technology/2
    -HP Fingerprint/Password conflict http://forums.adobe.com/thread/911575
    Mar 22, 2013 5:34 AM   in reply to debaniehael
    Mar 22, 2013 7:30 AM   in reply to debaniehael
    I tried getting into my BIOS but didn't see the option to reset there.
    Wait...did you actually get into the BIOS?
    Mar 22, 2013 11:15 AM   in reply to debaniehael
    You're right -- it's best to get the system problems solved first.  It may indeed make Pr work properly.
    Jeff
    Every similar message I have read about this kind of problem (many others that I did not include in the links I posted in #8) have indicated that Premiere (both Pro and Elements) will not run well... if at all... when a computer has switchable graphics adapters
    If your BIOS does not include any option to turn off the motherboard graphics chip, it is my opinion... from those other messages... that you will not get Premiere to work
    Mar 22, 2013 2:41 PM   in reply to debaniehael
    I do have Elements, and it works well enough. It does seem to take a very long time to load, but it does load, and it doesn't crash
    This appears to be normal, and goes back to at least PrE 4.0. PrE 11 is no quicker to load, about twice as long as any version of PrPro that I have used. Sometimes, if I re-launch PrE, it will load a bit more quickly, but still slower than PrPro does. Why? I have never read an explanation. I think that it is just the way that PrE is coded, and would not use its load time as a benchmark for anything.
    Good luck with the PrPro issues,
    Jan 27, 2014 5:43 AM   in reply to debaniehael
    It is possible that Adobe Premier Pro.exe is blocked in Firewall. Unblock it, if so.
