Hi I am facing severe pixellation problem on a moving object, when rendered in Elements 11. The source was Sony mini DV captured as AVI through Premier and then rendered as PAL DVD output. Strangely, this shows up when the disc is played on DVD player. Same problem when the MPEG file is played through windows media player or VLC player. Strangely if the clip is imported into Premier 11 then the pixellation disappears. Pls help. The video is uploaded at the following URL:
http://www.sandakphu.com/video/Traintest1.mpg and can be downloaded from following URL http://www.sandakphu.com/video. Pls look at the yellow vertical hendles on the moving train.
Dear Steve
Thanks for taking time to respond. Actually the pixellation is coming on the DVD being played thru TV as well. In some cases the picture is very choppy and severe. I repeated the capture using Windows Movimaker - and created a DVDin third party software, no problem there. Secondly, I converted the AVI file into MPEG HD 720 P and then created a DVD using a third party software - no issue tere either. The pixellation and choppy video is showing up specifically when I am writing into PAL DVD format from premier 11. I suspect there is a interlace setting somewhere that I am missing...
North America
Asia Pacific
