kazzuni
Problem with update form and date (show 1970-01-01)
Mar 22, 2013 5:02 AM
Tags: #php #date #1970-01-01
Hi, I've a update form (php/mysql) with many date input field. When my date is 000-00-00 I show 1970-01-01. Why??
This is the code:
label for="data_chiusura"><strong>Data chiusura</strong></label>
      <input type="text" name="Data_chiusura" value="<?php echo $string=$row_Recordset1['data_chiusura'];
    if($string == '0000-00-00'){
    $string = '';
    } else {
    $string = date("d-m-Y", strtotime($string));
    }; ?>" id="Data_chiusura">
k
    Mar 22, 2013 5:03 AM   in reply to kazzuni
    Because that's as far back as the date function goes. All dates are calculated from that point forward.
    Mar 22, 2013 6:42 AM   in reply to kazzuni
    Why would your date ever be "0000-00-00"?
    Mar 22, 2013 8:09 AM   in reply to kazzuni
    Why would the date ever be null? As long as the date has a non-zero, non-null value this function will work correctly.
    I'm a little confused by what you are doing here. So, you are pulling data from a table, and populating forms with it. This particular field is a date field, and the problem is that when the data for that field is a null, you are getting instead a date of 1970-01-01 displayed in that field - is that correct? What do you want to appear there when the data is null? Nothing?
    Mar 22, 2013 8:25 AM   in reply to kazzuni
    Try this -
    <input type="text" name="Data_chiusura" value="<?php $string=$row_Recordset1['data_chiusura']; echo empty($string)?'': date("d-m-Y", strtotime($string)); ?>" id="Data_chiusura">
    Mar 22, 2013 8:56 AM   in reply to kazzuni
    Try this -
    <input type="text" name="Data_chiusura" value="<?php $string=$row_Recordset1['data_chiusura']; echo strtotime($string) <= strtotime('')?'': date("d-m-Y", strtotime($string)); ?>" id="Data_chiusura">
    Mar 22, 2013 9:10 AM   in reply to kazzuni
    Good luck!
