Creating a bevelled edge is rounded
Mar 22, 2013 6:11 AM
Hi folks!
Might not be a good title....lol I am trying to create a graphic style that will give me a frame that has the 3d rounded effect. Bevel and Extrude isn't what I am looking for...
I have a pic here with a bevelled edge effect, but it has a flat surface...and I want it to look round...
    Mar 22, 2013 6:44 AM   in reply to bookie56
    Go here and look for a tutorial on license plates
    rwillustrator.blogspot.com/
    Mar 22, 2013 7:02 PM   in reply to bookie56
    For something similar to that rather laborious tutorial, simply apply two Drop Shadow Effects to the object. One black, the other white; offset in opposite directions.
    For a more rounded effect, use a blend as one normally would for shading. Then apply the drop shadows to the blend object.
    JET
    Mar 22, 2013 8:01 PM   in reply to bookie56
    Did this awhile back (Corel), inner (white) shadow technique once again.
    Mar 22, 2013 8:29 PM   in reply to bookie56
    If you're using Illustrator CS6 you might try experienting with the gradient stroke feature.
    Mar 23, 2013 4:14 AM   in reply to bookie56
    bookie,
    If you just want a rounded appearance like the one at the bottom (left) of this image from a rather old thread,
    depending on version you may use a stroke with a gradient across or an Artbrush based upon a blend across. Either way you may make it more or less rounded.
    Mar 23, 2013 6:22 AM   in reply to bookie56
    You are welcome, bookie.
    Mar 23, 2013 6:33 AM   in reply to bookie56
    Here’s another way.
    A fat black stroke blended into a thin white stroke.
    Mar 23, 2013 8:52 AM   in reply to bookie56
    I trashed the Illie file but it’s easy to do.
    Make a triangle and give it a good fat black or dark stroke with rounded joins.
    Copy it, thin the stroke and colour it white or light.
    Make a soft blend between the two.
    Direct Select the white triangle with Option/Alt held down.
    Release Option/Alt and drag to position (slightly off according to lighting).
    Give the whole thing a drop shadow (if you like).
