Configuration/Workspace/Designer.xml file missing
Mar 22, 2013 12:04 PM
My Designer.xml file is missing. Anyone know where can I find this?
  • kglad
    Jul 21, 2002
    Mar 22, 2013 1:10 PM   in reply to bingandham
    save the following to Designer.xml and move to C:\Program Files (x86)\Adobe\Adobe Flash CS4\Common\Configuration\Workspace
    <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
    <panelset>
      <application/>
      <document maximize="true" rect="0 0 500 500"/>
      <panelframe dock="left" height="801" width="282" x="0" y="12">
        <panelcontainer expanded="true" height="118" visible="true">
          <panel height="118" id="tools" unconstrainedheight="736" unconstrainedwidth="30" width="278"/>
        </panelcontainer>
        <panelcontainer expanded="true" height="637" visible="true">
          <panel height="637" id="droverproperties" unconstrainedheight="114" unconstrainedwidth="278" width="278"/>
        </panelcontainer>
      </panelframe>
      <panelframe dock="right" height="801" width="212" x="1" y="12">
        <panelcontainer expanded="true" height="350" visible="true">
          <panel column0id="1" column0width="230.00" column1id="2" column1width="230.00" column2id="3" column2width="70.00" column3id="4" column3width="135.00" column4id="5" column4width="70.00" filename="" height="350" id="droverlibrary" previewwithgrid="0" previewwithmoviebackground="1" sortasending="1" sortcolumn="1" splitter="0.34" unconstrainedheight="300" unconstrainedwidth="278" width="208"/>
        </panelcontainer>
        <panelcontainer expanded="true" height="114" visible="true">
          <panel height="114" id="align" unconstrainedheight="114" unconstrainedwidth="208" width="208"/>
          <panel height="114" id="info" unconstrainedheight="114" unconstrainedwidth="208" width="208"/>
          <panel height="114" id="transform" unconstrainedheight="114" unconstrainedwidth="208" width="208"/>
        </panelcontainer>
        <panelcontainer expanded="true" height="268" visible="true">
          <panel height="268" id="mixer" unconstrainedheight="268" unconstrainedwidth="208" width="208"/>
          <panel height="268" id="swatches" unconstrainedheight="268" unconstrainedwidth="208" width="208"/>
        </panelcontainer>
      </panelframe>
      <panelframe dock="top" height="146" width="543" x="0" y="0">
        <panelcontainer expanded="true" height="123" visible="true">
          <panel height="123" id="drovertimeline" isInLayerMode="false" unconstrainedheight="180" unconstrainedwidth="600" width="539"/>
          <panel height="123" id="keyframeeditor" unconstrainedheight="180" unconstrainedwidth="600" visibleTab="false" width="539"/>
          <panel height="123" id="output" unconstrainedheight="180" unconstrainedwidth="600" visibleTab="false" width="539"/>
          <panel height="123" id="compiler errors" unconstrainedheight="180" unconstrainedwidth="600" visibleTab="false" width="539"/>
        </panelcontainer>
      </panelframe>
    </panelset>
  • kglad
    Jul 21, 2002
    Mar 22, 2013 1:38 PM   in reply to bingandham
    you're welcome.
