Toolkit for CreateJS after export instance names are not available in .name property of objects
Mar 22, 2013 2:27 PM
Tags: #flash #cs6 #name #instance_name #createjs
Inside a loop I connect a single click eventlistener to multiple objects. Inside the event listener I need to know what Button or MovieClip is clicked on.
In AS3 I used event.target.name and it looks like createjs supports this because the property .name exists for all objects.
But the problem is that the name property is null in every object. I tried adding .name inside the exported js and that works, but to edit that file is not really an option.
I use this code for example :
for (i = 1; i <= 150; i++){
    myMC["childMC" + i].addEventListener("click",onChildClick);
function onChildClick(event){
   alert('clicked target' + event.target.name);
Is this a bug or something or better yet, is there a workaround?
    Mar 26, 2013 12:59 PM   in reply to ferryfast
    Is there any reason you can't use child-iteration?
    for (i = 1; i <= container.getNumChildren(); i++){
        container.getChildAt(i).addEventListener("click",onChildClick);
    Mar 30, 2013 4:49 PM   in reply to ferryfast
    Even though there is no name property, you could also probably use the existence of the property on the parent (similar to the name approach) since Toolkit injects the children using their instance name as the property name:
    var num = 0;
        var name = "myMC" + i;
        if (container[name] != null) {
           // This is a "myMC#" child
            container[name].addEventListener("click",onChildClick);
            num++;
    This would be easier if you knew the number of myMC children, since you could just use that as a loop instead of checking all the children.
    Aug 22, 2013 6:16 AM   in reply to ferryfast
       Here's how i do it:
                var someContainer=new lib.SomeContainer();
                for(var childName in someContainer){
                    if(someContainer[childName] instanceof createjs.DisplayObject) {
                        someContainer[childName].name=childName;
                        console.log(childName+" now has a name!!");
