I can't install Adobe Premiere Elements 11
Mar 22, 2013 5:27 PM
Tags: #premiere_elements11
I can't install Adobe Premiere Elements 11 from my DVD. I have tried downloading the trial version online but that won't work either. I tried using Internet Explorer 9. I have got 6GB RAM and 650+GB Hard Drive.
  • kglad
    Jul 21, 2002
    Mar 22, 2013 10:32 PM   in reply to David682
    why can't you install from your dvd?
    why can't you download and install the trial version?
  • kglad
    Jul 21, 2002
    Mar 26, 2013 7:27 AM   in reply to David682
    restart your computer and retry installing.
    if that fails, what file are you clicking to install?
  • kglad
    Jul 21, 2002
    Mar 26, 2013 9:08 AM   in reply to David682
    what's the name and extension of that file?
    where is that file located?
  • kglad
    Jul 21, 2002
    Mar 26, 2013 3:42 PM   in reply to David682
    you should be clicking on PhotoshopElements_11_WWEFDJ.exe
    go here, follow all 7 steps and download: http://prodesigntools.com/photoshop-elements-11-direct-download-links- pse-premiere-pre.html
  • kglad
    Jul 21, 2002
    Mar 27, 2013 9:11 PM   in reply to David682
    put both of those files in the same directory and then click the exe file.
    that should extract all the needed files.
    then click setup.exe
  • kglad
    Jul 21, 2002
    Mar 28, 2013 6:52 AM   in reply to David682
    did you extract the 7z file?  (you should not.)
    Mar 29, 2013 9:30 AM   in reply to David682
    extracting the 7z file means unzipping the contents of that file. However since you haven't done it then the setup should run properly. Please show me the file size of the .7z file by right clicking on it and clicking on properties so that I can check whether it has completely downloaded or incomplete download.
  • kglad
    Jul 21, 2002
    Apr 1, 2013 5:56 AM   in reply to David682
    right click setup.exe and click "run as administrator".
  • kglad
    Jul 21, 2002
    Apr 1, 2013 6:55 AM   in reply to David682
  • kglad
    Jul 21, 2002
    Apr 2, 2013 6:30 AM   in reply to David682
    you're welcome.
    what was the solution?  it may help others if you explain or mention what steps led to solving the problem.
  • kglad
    Jul 21, 2002
    Apr 2, 2013 6:50 AM   in reply to David682
    phew. that sucks.
    but, glad it's resolved and thank you for posting that.  i'll have to check further into it.
