ishwinderjauhar
GPU and rendering speed
Mar 23, 2013 6:40 AM
hi
i have the following system specifications and graphic card, my requirements/process is as follows-
01. I am encoding blurays 1080 59i, the source is over a network . The networking speed is 1 GBps.
02. The gpu is not going above 12% -20% while the rendering is taking place.
03.The cpu is at 100% usage.
04. Software used - adobe premiere cs 6 and windows 7 enterprise
Now the questions are-
01. Why is the gpu not getting used completely? What settings should i change or compatibility issues?
02. What kind of time frame are we looking at for rendering with the following specs of the system-
System Configuration
CPU   :                 AMD A10 - 5800K     4.3 GHz
Caches momory  :  L1D (16KB x 4)
      L1I - cache (64KB x 2)
                                      L2 Cache (2048 KB x 2)
Mainboard            :
                                        ASUSTeK     F2A85-M
                                       Chipset - AMD
Memory                   :    G.SKill  16 GB   DDR3     (8GB + 8GB) 1600 MHz
Graphics                   :   NVIDIA Geforce GTX 680 (Vram - 2048 MB DDR5
                        Cuda cores - 1536 )
HDD :
TOSHIBA ATA Device 500 GB
WDC ATA  2TB
WDC ATA  2TB
Nvidia control panel settings
Ambient Occlusion - OFF
Anisotropic Filtering - 8X
Antialiasing - FXAA    -   ON
Antialiasing - Gamma Correction  - ON
Antialiasing - Mode                           - override any application setting
Antialiasing - setting                        - 4X
CUDA GPUs                                          - ALL
Maximum Pre-render frames       - 4
Multi - Display                                     - Single Display Performance
Triple Buffering                                  -  ON
PhysX Settings - GPU
Premiere And Encore Settings
Premiere CS6  :  Source : AVI Motion JPEG
                                 Sequence Settings : Rovi Total Code - Bluray 1080 60i 29.97 fps
Footage Lenght : about 1 hour 30 minutes
Output :
  Media Encoder : MPEG2 Bluray
   Video : NTSC, 1920x1080 , 29.97fps , quality 4.0 , lower
    Audio : PCM, 48 KHz ,16-bit, Stereo
Encore Settings - MPEG2 Bluray High Quality
