AudioPrefetch.cpp-87 Error
Mar 24, 2013 7:12 AM
Brand new machine, brand new install of CS6!!! I swear I give up with computers! Nothing ever works right!!!!
Premiere Pro has encountered an error.
/Volumes/BuildDisk/builds/mightykilt/shared/adobe/MediaCore/AudioRende rer/Make/Mac/../../Src/AudioRender/AudioPrefetch.cpp-87]
Branched from an earlier discussion.
    Mar 24, 2013 7:13 AM   in reply to KeithHopkin
    [branched to new discussion]
    Lots of good troubleshooting and several possible solutions in this topic:
    Adobe Community: Very mysterious "AudioPrefetch.cpp-87" error
    Jeff
    Mar 24, 2013 8:10 AM   in reply to KeithHopkin
    And the last thing I need is wasted time on  buggy software!
    "Ain't nobody got time for that!"
    Mar 25, 2013 9:53 AM   in reply to KeithHopkin
    This is copied and pasted from a reply to another post.
    As for the audio prefetch error, to make a nested sequence show an audio waveform, you use the Clip menu and select Audio Options > Render and Replace.
    The prefetch error in some cases is connected to a file with an interpreted frame rate, so could you use the Render and Replace option to fix this? You will be making a new audio file at your interpreted frame rate so hopefully the problem will not occur.
